Old 03-08-2010, 09:42 PM   #29
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Originally Posted by Tom Nugler View Post
Does one in VR count?
I did this up last winter for a modeling project. Planned on using a Ford model A car kit for running gear and details. Body would have been embossed .010 styrene sheet, with bars and channels from Evergreen.
Best laid plans.. Picked up another Vintage trailer and have spent the last year working on the real thing.
Tom.
You guys are way ahead of me, I had thoughts of doing a model out of cardboard.
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 03-08-2010, 10:21 PM   #30
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Originally Posted by Minnie's Mate View Post
Current issues are carried by Books-a-million and others. You can also go to the Airstream Life web site and order a copy, IIRC @$8/copy.
Sorry to say Airstream Life is no longer in bookstores. But we do now offer digital downloads of certain articles on our website. You can buy a digital copy of Forrest's article for just a buck here. You'll get an immediate link where you can download your copy.
Or, if you want the entire Spring 2010 issue on paper, you can still buy it here.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 03-09-2010, 12:04 PM   #31
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by Forrest View Post
They're not Dale's, and really they're not even Dr. Holman's - the plans are Wally's.
I'm not talking legalities here since the copyright on the actual plans ran out long ago unless renewed, but just saying a courtesy would probably be appreciated since the image was cropped from one of Dale's. Technically and legally, Dale owns the copyright to his photo and his likeness (even thought cropped out). If those plans were part of his mother's estate, he would own them. Not sure if there is a difference between "borrowing" the image of the plans and "borrowing" the actual plans without permission.
I was unaware that they were no longer available in bookstores. I, too, have been a subscriber from issue one.
Family of Disney Fanatics
WBCCI# 4821
Old 03-10-2010, 01:19 PM   #32
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Aluminum Frame Idea
This is a layout using 2 x 3 3 x 0.125 aluminum rectangular tube
Name:	Torpedo Curb Side Plans Aluminum Frame.jpg
Name:	Torpedo Street Side Plans Aluminum Frame.jpg
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 03-10-2010, 02:32 PM   #33
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Nice work Tom. So what's the thought on a frame. I know a lot of teardrop guys start with the red HF frames with reinforcements & corner gussets, but a Chinese frame under that wouldn't work for me.
Frank, you said all aluminum for the walls, are you talking about Al for the frame as well?
newroswell is offline   Reply With Quote
Old 03-10-2010, 02:54 PM   #34
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
I'm thinking of () using a recovered pop-up camper frame. I've got my eye on a popup in which the canvas and the floor are shot. The guy wants 100 bucks for it. I figure strip it down and make sure the frame is prepped for reuse. From there I would lay the flooring and mount the frame atop the floor the same as current Airstreams are done. The exterior would be covered with aluminium. The only drawback with using rectangular tubing is the riveting will have to been done with blind rivets (structural, multi-grip or tri-grip).
Tom
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
Old 03-10-2010, 03:07 PM   #35
Chief Chili Cook
newroswell's Avatar
That's a good idea Tom, then you've got a VIN the DMV will like.
Old 03-10-2010, 03:21 PM   #36
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Yep, and in WV they don't look to see if the trailer matches with any of the numbers.
Tom
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
Old 03-10-2010, 04:15 PM   #37
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Good idea on using a recycled frame. When I photo dimensioned my plans I think I came up with a 3" tall frame rail. Bigger might be better however.
Why not use z bar. That'll make riviteng a lot easier.
Z62032; 1 x 2 x 1 x 3/16 in - Aluminum Corners, F, h, H, T and Z - Aluminum angle, Aluminum tube, Aluminum extrusions, Anodized aluminum, Aluminum pipe, Aluminum channel, Extruded Aluminum angle, brunner enterprises, Aluminum bar, aluminum rod, alu=
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 03-10-2010, 04:37 PM   #38
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
"Why not use z bar. That'll make riviteng a lot easier."
I like the structural strength of the rectangular framing idea because I've seen our machine shop guys bend it and form it for equipment repairs. It seems to hold the shape well after the bend with very little compression of the thickness along the bend. That was my first preference I jumped on. C-channel requires to much care to avoid distortion when using a home bending jig. Z-bar would probably be good for the sidewall struts, where straight pieces are required. I'm not an engineer, just guessing.
It's (aluminum) got to be better than plywood, especially for longevity of the trailer.
Tom
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
Old 03-10-2010, 04:58 PM   #39
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Of course if you really wanted to go high tech........
There's carbon fiber
http://dragonplate.com/ecart/categories.asp?cID=56
Tom
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
Old 02-15-2011, 06:40 PM   #40
Chief Chili Cook
newroswell's Avatar
So how is everyone doing with their Torpedo builds? Any new thoughts?
Old 07-18-2012, 11:03 AM   #41
cuyeda's Avatar
Long Beach , California
Ditto... on how is everyone doing on building one of these? Inquiring minds would like to know. Any update on builds?
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 08-01-2012, 03:53 PM   #42
Arrowstream's Avatar
Columbia , South Carolina
Does a teardrop version qualify?
Teardrops n Tiny Travel Trailers • View topic - 1935 Torpedo
ID:	164456   Click image for larger version
Arrowstream is offline   Reply With Quote
1935 Byam kit plans Forrest Vintage Kin 6 12-29-2006 04:41 PM
Seeking plans for dinette FrankR General Interior Topics 24 05-01-2006 01:27 AM
destinations john hd On The Road... 93 04-28-2004 09:11 PM
Description of Remodeling Interior Cat General Interior Topics 12 08-13-2002 10:03 AM
My plans for a neet Airstream FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-08-2002 01:30 AM
