Old 11-20-2015, 03:13 PM   #1
gomotomoto's Avatar
Longport , New Jersey
To tarp or not to tarp?
I just put our airstream away for winter storage and I noticed a few other trailers have blue tarps over them. Should I put one over mine?
gomotomoto is offline   Reply With Quote
Old 11-20-2015, 03:15 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The common response will be " NO". We don't and all has been good. I might think along those lines though if I had to park under some messy trees but expect most responses to be a resounding NO
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-20-2015, 03:16 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Not....unless you have a leaker with a poor exterior finish.
CRH is offline   Reply With Quote
Old 11-20-2015, 03:21 PM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
No, our three are stored outside in Pittsburgh, PA area. I wash and wax twice a year and check the seams every year and redo as necessary. A cover will move and scratch the aluminum
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 11-20-2015, 03:49 PM   #5
richw46's Avatar
Lexington , Kentucky
Ours stays outside year round. I too wash and wax twice a year, just had all the roof seams cleaned and sealed at Jackson Center. The pressure test and storm water test at JC showed no leaks. The PO of ours stored it outside as well. I've seen blue tarps flapping and moving with the wind. I'd be afraid it would scratch or cause mold to develop. At least in winter, the sun is our friend.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 11-20-2015, 03:55 PM   #6
Normal , Illinois
Don't do it.
Maggie
Old 11-20-2015, 05:09 PM   #7
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
All the above, I am in NJ too. I have wheels up on those orange blocks, off the ground and tires have covers. I also put a five gallen bucket over the electric hitch. Everything comes out
, bedding, clothes, food etc , fridge and freezer doors propped open., all cabinets are opened and I use just under 1 million dryer sheets inside.
If we get a good amt of snow, i very very carefully use soft snow rake and get it off roof. I check once a week.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 11-21-2015, 04:04 AM   #8
gomotomoto's Avatar
Ah, didn't think of the wheels. Should I roll them onto something? Good tip with the bucket!
Old 11-21-2015, 11:33 AM   #9
1996 25' Excella
Tillsonburg , Ontario
If neighbors are covering their trailer in indoor storage ( you didn't specify) it is just for keeping the dust and bird poop of the trailer. Outside, Blue Tarps will flap in the wind and scrub the aluminum finish. as noted above the general consensus is NO
JCW
JCWDCW is offline   Reply With Quote
Old 11-21-2015, 11:50 AM   #10
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
No! It will abraid your finish and it locks in the moisture around your trailer, worse than the abrasion.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 11-21-2015, 11:57 AM   #11
Images: 59
I tarp mine.
However its parked inside my daughter's barn. No wind but more than a few pigeons. Also it's not clearcoated so I don't have that to deal with.
Old 11-21-2015, 01:17 PM   #12
1976 Argosy 26
Los Altos , California
We bought an Argosy in 1977 because of Airstream's reputation for solid construction. Almost 40 years later, we have never had a leak. I never dreamed of covering it.
CA_CAJUN is offline   Reply With Quote
Old 11-21-2015, 01:52 PM   #13
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Best way to cover your Airstream in winter, should you wish to do so, is to park it at a covered storage place. We do that. Some folks also keep a Battery Tender+ on their batteries to keep them happy. Since we replaced the stock Parallax converter with a multi-stage Progressive Dynamics unit, we just keep the trailer plugged in to 15 amp power all winter and leave the switch in "USE".
Rocinante is our 2014 International Signature 27FB
Old 11-23-2015, 09:15 PM   #14
sroach's Avatar
2012 23' FB International
Warrington , Pennsylvania
Can I ask what kind of wax you guys are using?
sroach is offline   Reply With Quote
Snow-region Argosys - Tarp or no tarp? pxlchk1 All Argosy Trailers 9 12-29-2013 12:31 PM
Tarp O.K. for Winter Cover boutdoors Winter Living 7 03-19-2011 09:43 PM
Help! Black marks on exterior from plastic tarp kar2879 Exterior Restoration Forum 4 07-19-2010 12:29 PM
How do I remove black tarp marks? crdouger Cleaning, Stripping & Polishing 3 07-19-2010 07:59 AM
Tarp/faux leather Softening Home Remedy Sought Distantdrummer Off Topic Forum 2 08-08-2009 03:15 PM
