Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-07-2009, 07:29 PM   #1
Doohickey's Avatar
2009 19' Flying Cloud
Bordentown , New Jersey
Tire pressure monitoring.
Hello Everyone,
Has anyone tried, or still using, a tire pressure monitoring system? I tried to search this question in previous posts and found nothing, so if this has been answered before please tell me where.
Doohickey is offline   Reply With Quote
Old 08-07-2009, 08:01 PM   #2
richinny's Avatar
2011 34' Classic
http://www.airforums.com/forums/f160...tem-50320.html
http://www.airforums.com/forums/f206...tem-24526.html
http://www.airforums.com/forums/f438...tem-35065.html
Ricky
Old 08-07-2009, 08:09 PM   #3
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I use the PressurePro tire monitoring system. If I can be of any help, let me know. It's worth the investment, especially for a single axle trailer.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 08-07-2009, 09:59 PM   #4
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Schrader (AirAware) is producing the majority of the TPMS used in new cars. They have a kit for cars but say not recommended for trailers. I contacted them to ask why and as expected it's because the radio transmitter in the valve stem isn't designed to reach far enough. However, they do have a booster system in the works which will mount in the trailer and relay the signal to the car. It will register temperature and pressure in each tire. Looks like a pretty good system.
bhayden is offline   Reply With Quote
Old 08-07-2009, 10:00 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I'll second what SilverRanger says...well worth it...we've used PressurePros since Dec07 ...check out the threads listed above...there is a lot of discussion...PressurePros (or similar products) are used by many Airstreamers...
Good luck!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-14-2009, 10:08 AM   #6
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
can hardly wait
... for my Doran 360RV to arrive next Tuesday. Based on this and other threads/reports, I ordered a 6-sensor configuration (single axle Safari + TV) in preparation of an upcoming up-the-California-coast and through-the-Sierras loop for Labor Day week.
Hopefully I'll only be reporting on how at ease I am with the system.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 08-14-2009, 02:17 PM   #7
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Thumbs up
Good move, 5cats. I really hope it works out for you.
Have a safe trip.
2005 Bambi
1968 Trade Wind
WDCU
Old 08-14-2009, 03:14 PM   #8
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I love my Pressure Pro system. I have had it over a year now and its just great. For one thing I don't have to use a gauge and check the tires before leaving on a trip. It tells me the pressure of each one from the drivers seat. Then on the road I can monitor each tire as I drive.
What I really like is the fact that it also gives me the tires temperature. Tires that blow out usually get very hot before exploding. Knowing the temps is a good indicator of pending problems.
I just ordered two more sensors for my tow dolly, and a relay to extend the range of the system.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 08-14-2009, 06:37 PM   #9
1998 28' Excella
Dolores , Colorado
We ordered our Pressure Pro system today. We have heard nothing but good remarks about this system. I learned a trick this past weekend when we had some friends staying with us and they have the Pressure Pro. If you don't have the sensors pretty tight you will cause the tire to leak air and set off the monitor.
Hope to have the system installed when we head for the rally at Lake Heron, NM.
Member 4CU/CAC
WBCCI 10105
AIR 28748
dogpound is offline   Reply With Quote
Old 08-14-2009, 07:41 PM   #10
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
For what it's worth, here's a tip. I recently had new tires and metal valve stems installed. I was there during the installation, and showed the service manager my sensors and asked him if the tires should be balanced with the sensors on. He said "absolutely", and allowed me into the shop to install them before them just before they balanced the tires. I had heard the weight of the sensors was negligible, but apparently not.
2005 Bambi
1968 Trade Wind
WDCU
Old 08-15-2009, 03:28 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Member 4CU/CAC
WBCCI 10105
AIR 28748
Bob...You are really going to like the tire pressure mopniotres...we swear by them! See you at Lake Heron!
SilverRanger...Good move...we did the same thing....metal valve stems and balancing with the sensors in place.
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-16-2009, 08:19 PM   #12
1998 28' Excella
Dolores , Colorado
Pressure Monitoring
We had the metal stems put on too when we put on our new tires. We have driven many miles without them but...it only takes one time.
Terry I have read in your travel log that you have found low tires with the monitor and that helped us to make the choice. Also when you take long trips and forget to check the tires every stop.
See you in Heron. Bob
Old 08-17-2009, 01:58 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Bob...You won't be sorry about getting the tire pressure monitors...we haven't been...
Looking forward to seeing you and Lou at Lake Heron!
Rally on!
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-17-2009, 02:21 PM   #14
ZoominC6's Avatar
2004 30' Classic Slideout
2021 33FB Classic
Colleyville , TX
Since 2005
Pressure pros can save you their expense in blown out plumbing valves or aluminum skin damage in case of a tire shredding episode. We've had ours for four years and have yet to change batteries. Careful attention to the installation instructions will make installation very easy.
Another 'wheel item' worthy of consideration would be Centramatic automatic wheel balancers used by over the road truckers. They're relatively inexpensive, easy to install and another good insurance move. Painting them flat black prior to installation will allow the spokes of your Alcoa wheels to retain their spoked appearance.
Good luck with all of your 'wheel' decisions.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Tire pressure monitoring kittrik Tires 13 09-26-2009 01:42 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 09:08 AM
PressurePro Tire Pressure Monitoring Systems PatMcFall Commercial Listings 0 12-28-2007 02:04 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 03:49 PM
