The Amazing Mr. Clean Carwash Machine
Just picked up one of these up at Wally World. It is basically a soap dispenser with a special filter cartridge. You soap down the vehicle in the "Soap Mode" then hand wash with mitt or sponge. You then turn the selector to "Rinse Mode" and rinse the soap off. Before the rinse water dries go to "Spotless Rinse" and rinse it down again. It uses a little bit of soap to break the surface tension of the water, and uses the filtering system.
It comes with a starter bottle of soap and filter for 3 washes, which only did the car and pickup. Refills do 10 washes.
I'll try the A/S later on. Seems to work as advertised with our calcium laden water.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
