Old 08-30-2016, 09:28 AM   #1
2016 26' Flying Cloud
Glenville , New York
Tahoe Tow Vehicle
My husband and I bought a 2016 Flying Cloud 26U. We also bought a 2013 2WD Chevy Tahoe to tow it. He is worried that the 26U is putting too much strain on the Tahoe transmission. Has anyone else towed this size airstream with a Tahoe for a long trip? For instance a trip from Florida to NY...
Dustyrodes is offline   Reply With Quote
Old 08-30-2016, 09:44 AM   #2
ericpeltier's Avatar
Superior , Colorado
A 26' airstream is a smaller load than what a Tahoe is "designed" for. Just be sure it has a transmission cooler and oil cooler.
(I am not and will not comment on Payload, Tongue Weight, GCVW, etc)
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 08-30-2016, 09:51 AM   #3
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
We have a 2013 Tahoe LTZ and tow 25' AS, did 9,000 miles in the last 18 months from PHX to Canada. The trick is take your time and slow down, keep your Tahoe service up to date, we find that staying off interstate as much as we can and taking side roads is much more enjoyable and less stress on you and your rig.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 08-30-2016, 11:09 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A good way to avoid putting stress on the transmission is to select a lower gear and keep it there if the transmission keeps shifting up and down. Not sure which engine/rear axle ratio you have but the engine will probably be comfortable in the 2200 rpm range with the least amount of transmission gear hunting.
On steep hills, shift down and let the engine rev above 3000 rpm to get the torque range you need for climbing, and do the same for descending those hills to get the engine compression braking you will want.
You will learn to use the transmission shifter to get the best performance and least amount of strain.
Doug and Cheryl
Old 08-30-2016, 12:34 PM   #5
2005 19' Safari
ishpeming , Michigan
I would also add a brake controller if your vehicle is not already equipped. A 2013 Tahoe is also probably equipped with a manual shifter located on the shift lever. Mine was a toggle switch showing a + & -. Also is a button located on the end of the shift lever, when engaged, will assist your engine to shift better while towing.
amazingwoody is offline   Reply With Quote
Old 08-30-2016, 12:57 PM   #6
dames7's Avatar
GILBERT , Arizona
I think only the Tahoe LTZ have the switch showing a + & -. Also the button located on the end of the shift lever, when engaged, will assist your engine to shift better while towing.
David & Nancy Ames
2015 FC 25' RB
2015 Chevy Tahoe tow vehicle DeltaRon On The Road... 19 07-11-2014 09:17 AM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 01:55 PM
Best Tow vehicle for 08', 25'-Tahoe work? gypsydad 2008 Safari SE 19 06-19-2012 06:01 PM
2004 Chevy Tahoe Z71 as Tow Vehicle? aversenti Tow Vehicles 13 10-18-2006 12:01 PM
