Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 03-12-2005, 08:52 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Suburban Brake Recall
This is my second attempt at posting this Suburban Brake Recall:
1) If you're the original owner and GM has your address, they'll send you a postcard every few weeks until you respond.
2) It's a relatively small number of vehicles
GM RECALL NO. 04004.
Make : CHEVROLET Model : SUBURBAN Year : 2003 / 2004
Manufacturer : GENERAL MOTORS CORP.
NHTSA CAMPAIGN ID Number : 04V045000 Recall Date : JAN 28, 2004
Component: SERVICE BRAKES, HYDRAULIC
Potential Number Of Units Affected : 68875
Summary:
CERTAIN SPORT UTILITY VEHICLES, PICKUP TRUCKS, AND PASSENGER VANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 135, "PASSENGER CAR BRAKE SYSTEMS." SOME OF THESE VEHICLES WERE PRODUCED WITH AN OUT-OF-SPECIFICATION BRAKE HYDRO-BOOST HOUSING RELIEF VALVE BORE.
Consequence:
CONSEQUENTLY, THE VALVE O-RING SEAL MAY FRACTURE. STEERING EFFORTS MAY BE SLIGHTLY INCREASED WHILE BRAKING OR PARKING. UNDER CERTAIN DRIVING CONDITIONS, A FRACTURED SEAL MAY REQUIRE A SLIGHT INCREASE IN THE APPLIED BRAKE PEDAL EFFORT TO ACHIEVE THE SAME VEHICLE DECELERATION RATE AS PRIOR TO THE SEAT FRACTURE.
Remedy:
DEALERS ARE TO REPLACE THE HYDRO-BOOST RELIEF VALVE. THE RECALL BEGAN ON APRIL 26, 2004. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2339; CHEVROLET AT 1-800-630-2438; GMC AT 1-866-996-9463; OR HUMMER AT 1-866-486-6376.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
GM RECALL NO. 05006.
Make : CHEVROLET Model : SUBURBAN Year : 2004 / 2005
NHTSA CAMPAIGN ID Number : 05V043000 Recall Date : FEB 04, 2005
Potential Number Of Units Affected : 155465
Summary:
CERTAIN TRUCKS, SPORT UTILITY VEHICLES, AND VANS EQUIPPED WITH BOSCH HYDRO-BOOST BRAKE ASSEMBLIES, THE HYDRAULIC BRAKE BOOSTER PRESSURE ACCUMULATOR MAY CRACK AND SEPARATE FROM THE HYDRO-BOOST ASSEMBLY DURING NORMAL OPERATING CONDITIONS.
Consequence:
IF A SEPARATION OCCURRED AND THE HOOD OF THE VEHICLE WERE OPEN, FRAGMENTS FROM THE ACCUMULATOR COULD CAUSE INJURY TO PEOPLE IN THE IMMEDIATE AREA. THE PRESENCE OF THIS CRACK OR FRACTURED SURFACE COULD ALLOW THE HYDRAULIC FLUID TO LEAK FROM THE ACCUMULATOR CIRCUIT OF THE BOOSTER ASSEMBLY. THE LOSS OF FLUID WOULD CAUSE INCREASED STEERING AND BRAKING EFFORT AND A CRASH MAY OCCUR WITHOUT PRIOR WARNING.
Remedy:
DEALERS WILL TEST THE HYDRO-BOOST ASSEMBLY FOR FUNCTIONAL OPERATION OF THE TWO-FUNCTION VALVE. IF THE HYDRO-BOOST ASSEMBLY FAILS THE TEST, DEALERS ARE TO REPLACE THE ASSEMBLY. THE RECALL IS EXPECTED TO BEGIN DURING MARCH 2005. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, GMC TRUCKS AT 1-866-996-9463 AND HUMMER AT 1-800-732-5493.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-327-4236.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Chevy Express vs Suburban alan Tow Vehicles 8 07-27-2003 03:38 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
