12-29-2010, 06:58 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
Store with stabilizers??
I have been storing my Stream for almost a year now off and on in the same spot. It rarely sits longer than 2 months. It is backed up in my driveway next to fence. I have not put the stabilizers down while storing. I can't get to the front left side because of the angle. So my questions are,...
Should I use my stabilizers to prevent rear or front sagging? Like stated I can't get to the front right no matter what. Just use three, or it doesn't matter.
I see them parked from Vintage to New w/o them down unless camping. Just say'n.
2010 25' International
Thank-you,
Shane
12-29-2010, 07:06 PM
Southwestern
, Ohio
I dunno. . . we never put our stabilizers down when storing. As far as "sag", weight on the frame is minimal in storage (assuming the tanks are dumped!) and the trailer is not subject to being bounced over bumpy roads.
As far as I know the only purpose of stabilizers is to keep the trailer from bouncing around on the suspension while camped.
That, and the lighter single-axles trailers can actually sit up on the rear bumper if too many people congregate aft of the axle.
12-29-2010, 07:13 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Lucy is a 2005 Safari 25FB that has logged almost 70,000 miles and 770 nights of camping. When Lucy is not in a travel status, she is in our driveway in the alley behind our house. We have never put Lucy's stabilizers down other than when we are camping in her. We have not noticed any problems.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-29-2010, 08:43 PM
moderator
2016 27' International
Wilton
I devised a simple set of 13" 2x4's that while backing into my parking spot (which is on cement), I place under the axle mounting plates and back up about two more inches. The trailer lifts about 1" which in my mind relieves the load off the axles substancially. I think it would take nearly 3 inches to lift the tire off the ground. Then I put the stabilizers down to where they just barely start to lift. I lock the two tandems together with the wheel locks... The trailer is now supported in 7 positions and feels as stable as a house when you walk inside. When its time to leave the jacks come up, hitch it up and pull forward while the blocks fall away. Is this necessary? probably not. Will it extend the life of my axles? probably not. Will my airstream last longer from the extra attention? probably not.. but it makes me feel better
Vinnie
12-29-2010, 09:02 PM
A.K.A "THE STREAM"
Arlington
Vinnie
Before I got into the second sentence I was thinking,...I'm on the way to Home Depot in the morning.....
Shane
12-29-2010, 10:57 PM
2005 22' Safari
Hyde Park Place
, Ohio
Right now, I would do this in wood. After my welding refresher class in April-June, I would do it in metal!
TX-16
12-29-2010, 11:09 PM
Salem
, Oregon
Hi, stabilizers up when parked at home; I would only be able to do the street side if I did.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-30-2010, 01:03 AM
2005 19' Safari
GLENDALE
, AZ
I think I have put our stabilizers down twice since we bought our Airstream in 2005. I just told my wife she couldn't jump on the bed anymore, and that was that...
12-30-2010, 06:38 AM
Oswego
I do put down my stabilizers during extended storage only when up on jack stands. This has nothing to do with frame sag....etc. Where I store it is next to a large corn field, so there is about 800 yards, or more, of NO wind break to the west.
Its probably fine on stands w/o stabilizers, but I'd hate to find holes in the belly due to falling off the stands. The stabilizers just add 4 more points of friction/stability in windy conditions.
12-30-2010, 07:30 AM
Austin
After your welder refresher class in April-June, I might be calling you to come help me with my front-end frame-rot!
12-30-2010, 07:50 AM
2005 22' Safari
Hyde Park Place
, Ohio
I'd be happy to. Just need to freshen up my skills and get certified... ACC is good for that, and now Round Rock gets in-area tuition rates... (We've been paying the ACC taxes long enough!)
TX-16
12-30-2010, 09:25 AM
1977 27' Overlander
1963 19' Globetrotter
Naples
I would never store with stabilizers down,with my luck,I`d have a tire go flat and crunch a stabilizer.If you are using jack stands,then I see no problem,unless it fell off the jack stands. Dave
12-30-2010, 12:12 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
Stabilizers make such nice climbing structures for mice.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
12-30-2010, 12:56 PM
Oswego
Pat
Mice can jump 12" vertically. If there is an entry point anywhere under an AS, they'll find it. Like onto the sewer pipes and into the tank pans....from tires and axles into any number of gaps. On my AS there is no entry point any closer to the stabilizers than any other point of entry.
Sealing any possible points of entry is job one. When you finally get there, no more mice. Took me 2 seasons on my old SOB to get mouse free, then fine for 15 more years...no mice. This is the first winter with AS...so far no mice. In my climate, mice don't move much once the first long hard freeze occurs. They burrow in for the winter, and unless their nest is disturbed, they don't move around much, as far as relocation is concerned.
Just my observations from experience, for what it's worth.
12-30-2010, 03:04 PM
My concern as well. I've seen this on a few SOB's parked long term. Slow tire leak = buckled stabilizer.
Kevin
William C. Swinney
