Old 11-23-2017, 07:04 AM   #15
Selmer , Tennessee
Originally Posted by Eagle & Bear View Post
Before installing the flooring be sure to check for any rot in the plywood. Repair the floor as you see fit and then paint it with "Rot Doctor" two part epoxy. It will take several gallons to make the floor resistant to mold and fungal growth. Just make sure you have several fans to pull in fresh air while you are painting it on.
Peel n stick is good but you can put anything on the floor that appeals to you but keep in mind that you will want to redecorate every three to four years. Consider the weight of the material before buying. Lighter the better.
Is Rot Doctor the manufacturer name and is it sold under other names ?
Betto504 is offline   Reply With Quote
Old 11-24-2017, 12:17 PM   #16
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
It has been 8 years since I last ordered Rot Doctor. The company was in Seattle. Rot Doctor was being used to repair the wood on boats. If you cannot locate Rot Doctor see if you can find a two part epoxy with a viscosity below 3 (viscosity of water is 1). You want a pot time of more than 15 minutes so that it will penetrate the wood below the surface layer. In the long run it will prevent liquids from being absorbed and stop any rot from spreading.
Eagle & Bear is offline   Reply With Quote
Upgrade for the 1979 vintage stereo speakers blickcd Audio, Video & TV 2 11-22-2017 10:27 PM
HughesNet Gen 5, ZTE Mobley, etc., etc... Jaxon Electronics & Connectivity 1 09-12-2017 08:47 PM
Need stereo upgrade advice??? samiam8888 Audio, Video & TV 16 10-18-2012 10:16 PM
Stereo ALANSD General Motorhome Topics 9 09-30-2002 07:26 AM
Replacing Motorola Stereo montanaandy Electrical - Systems, Generators, Batteries & Solar 1 09-03-2002 06:44 PM
