Old 08-16-2017, 06:22 AM   #15
Rivet Polisher
1973 31' Sovereign
Mt Pleasant , North Carolina
Looking good, you'll find that it's like quicksand, the more you do the more you'll sink deeper into the project!
We had a metric ton of mouse poo in the flooring and walls, so much so that we decided not to put the aluminum skin back on the belly.
After months of working on ours we finally took it out for its maiden voyage, that made all the headache and skinned knuckles worth it.
-Jim Pantas
1973 31 ft Sovereign
2009 Chevy Express 3500
wildhorses is offline   Reply With Quote
Old 08-17-2017, 12:30 AM   #16
1974 Argosy 28
Euless , Texas
You're rolling around with no belly pan? I assume it's sealed similar to a pontoon. Any extra drag caused? Just curious if you've had any issues. I'm thinking of using a high grade plastic underneath to avoid corrosion and it's MUCH easier to work with.
Cfullertx is offline   Reply With Quote
Old 08-17-2017, 06:20 AM   #17
Boxite's Avatar
2008 22' Sport
That belly-pan is actually intended to PREVENT rodents and vermin. YOur's may not have been properly sealed, however. I recommend you reinstall it and seal it up.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-18-2017, 06:08 AM   #18
Rivet Polisher
1973 31' Sovereign
Sealed or not, persistent rodents and vermin will get in the smallest of holes or chew thru to make a hole, after finding the mess we did on the under belly we decided to leave it off.
-Jim Pantas
No Luck in Tow Vehicle Forum, Soooo. StreamGlider Airstream Lifestyle 0 05-21-2016 04:49 PM
I don't want to just toss this...soooo Sandi & Bob Vintage Kin 1 05-12-2015 03:27 PM
Now for the fun part..... donmyrick Interior Restoration Forum 2 10-05-2012 10:53 PM
Has anyone 'streamed while on crutches? I'm soooo frustrated... J5MM Off Topic Forum 11 07-23-2011 11:43 AM
Hi everyone! Soooo excited to be here! rtoaster66 Member Introductions 8 06-29-2009 11:14 AM
