Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-21-2005, 08:58 AM   #1
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
solar effect?
after a little over an hour on the interstate, i pulled over in a rest area to pour some water off the potatoes...before heading out, i did a walk around. i noticed the hubs on the shade side were cool as a cucumber, but on the sun side they were very warm. has anyone else noticed this phenomena?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 06-21-2005, 09:29 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Unhappy Ummm...
norby
Every time I work on my Airstream in the sun. Black tires and wheels will attract and hold more heat, especially in the sun, even when going down the road. You can expect them to be significantly warmer on the sunny side than on the shady side.
(No Longer at Inland RV)
Old 06-21-2005, 10:22 AM   #3
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Tire presures ...
Remember that phenomenon when checking tire pressures in the morning. Get to them before the sun!
For other temperature monitoring get one of these Gizmos not much expense for a valuable tool.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 01:06 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 10:25 AM
Solar Installation cactushead 2001 Safari 19 10-21-2002 06:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 08:47 AM
