Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 03-20-2003, 05:03 PM   #1
nwclassic
Profile:  2002 25' Classic
Vancouver , Washington
solar boost 2000E
We are going to go solar soon. Some info from a Solar Boost 2000E owner re depth requirements to flush mount would be helpful. The intent is to use the fwd galley wall behind which is the stored prewire ends. I have the LxW numbers, but no depth. Could I get away w/flush mounting along the left wall or would the oven make that a no go? Many thanks in advance.
nwclassic is offline   Reply With Quote
Old 03-20-2003, 05:28 PM   #2
JaceBeck
Profile:
I just got mine. It is about 1 1/2" deep. I choose to get the surface mount box, which is pretty big, but the hole you have to cut without the surface box is sizeable. This way I can take it with me when I upgrade to a larger rig since I will only have to drill holes for the wires.
Jace
Send me a PM if you have more questions.
JaceBeck is offline   Reply With Quote
Old 03-20-2003, 09:21 PM   #3
nwclassic
Thanks, Jace -- Good point re the cutout hole size. We're going to install a Link 10 in the same area (which can be flushmounted on that left side). I preferred to have them both the same mount, but the raised mount (I'm told) shows wires when installed... no such problem w/the solar boost. I guess it'll be one flush, one raised. Good luck w/ the new toy. Brian
solar 4 our AS lee Generators & Solar Power 10 07-05-2003 07:19 AM
solar advice nwclassic Generators & Solar Power 32 02-19-2003 10:17 AM
Generator or Solar? dmac Generators & Solar Power 9 02-17-2003 10:24 AM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 09:28 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
