I'm very tempted. Being a rookie at this, I thought I'd run it past you guys for some opinions....
Trailer is a '73 Safari 23. It appears to be in excellent condition. I was very impressed with the finish on the skin...most pics I've seen, and even a few in person, don't look nearly this good. (you know those typical spots of peeling clear-coat? none of that....). The inside is very clean, which makes me think that these folks have taken very good care of the trailer. Nice upholstery...brand new drapes that the mrs. made herself that look like they could have come from the factory. It has the original water heater, works fine. Brand new dometic fridge, which they told me cost 1600 bucks when all was said and done; cabinetry had to be modified to make the new model fit, which was done professionally. (hence the high price, I imagine). It has a fairly new Coleman A/C unit. The floors seemed to be in good shape, from what I could tell by walking around. I couldn't see any sign of leaks or water damage. The bath looks perfectly fine. Still has mostly copper pipes. All the light fixtures work. Their plastic lenses are all yellowed, though, and the owner said that he was unable to find replacements for them. (not a big deal.).
Tires are 3 years old, and look fine. Electric brakes were installed at the same time. I looked at the axels (read Andy's article at inlandrv.com), and didn't see anything that was obviously out of order. There also didn't appear to be any sign of rear-end separation. The belly looked good for a 30 year old unit.
Someone told me recently here that gray-water tanks started in 73, but this one didn't have one. The owner showed me the sewer hookup in the back...looked fine. They only camp at places w/ full hook-ups, so its not an issue for them.
The trailer also has full length awnings on both sides...all the windows open and close like they should. The only thing I could see that will definately need addressing is the propane tanks...they look like they're in good shape, but they don't have OPDs on them. The valves, though, unlike my gas grill tank, look like they can be changed...perhaps you guys can clue me in on that. either way, it doesn't seem like a big deal.
Sounds like a good deal to me. I paid $4,000 for a '72 31' and have had to put quite a bit of work into it, plumbing wise. I may have to replace my axles too, but they are fine for camping in a 200 mile radius, but not a 1300 mile trip to Florida. Ask them if you can hook the water up and check for leaks, and see if the cold water heating tank works. Fire up all the propane appliances too. The $6,000 sounds like a fair price.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
This trailer looks in great shape. I also have a 1973, 23 foot Safari. With a new refrig. and newer air conditioner and good tires, the price is about right. It doesn't hurt to offer less. Your's appears to be in better shape than mine. My trailer only has one awning, with some clearcoat wear on the top. I do have a 1X4 foot solor panel that works well. I am replacing the converter and all the cusions and need to fix the tambor doors also. All my utilities work fine. I had a leak where the antenna cable enters the roof. The insulation in the ceiling was like a sponge and shorted an inline wire crimp connector to the body. This caused my new battery to draw down. I sealed the leak and dried out the insulation. This cured my problem. I can't tell you the price of mine as my parents gave the Safari to me two years ago. I've always felt mine was worth about $5K. If you buy this trailer, lets keep in touch. It would be benefitial to both of us to compare notes from time to time. I live south of Seattle, in Wash. state.
