Old 09-23-2016, 11:06 AM   #1
2016 28' Pendleton
Slidell , Louisiana
Snowing on our maiden voyage...newbies!
Maiden voyage and temps dropping to 29 tonight. Yikes what do we do in our 2016 Pendleton airstream?
Penelope777 is offline   Reply With Quote
Old 09-23-2016, 11:08 AM   #2
2012 19' International
Southeastern MI , Michigan
Turn on the heat! 29 is barely below freezing.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 09-23-2016, 11:12 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
When we moved from So Cal to Wisc we had the same concern. It turns out if the low is only for an hour or so it will not affect the plumbing. If the day and night temp is going to be below 32 deg then get that trailer winterized right away.
Dennis
dennis3751 is offline   Reply With Quote
Old 09-23-2016, 11:25 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Fill the fresh water tank then disconnect the water hose and drain it. Let the furnace run tonight. Everything should be fine.
You must be a long way from home since the only location in the lower 48 with that forecast low is along the border of Oregon/California.
add edit:
I don't know if you have a macerator pump for your sewer outlet. I have no experience with those. If you do, hopefully someone will offer advice.
Alan
Old 09-23-2016, 11:27 AM   #5
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
You will be fine
Keep the furnace on and enjoy it.
If it is going to stay below 32F for a while, a heated water hose is a good idea.
Even in the pic below when it was 8F outside we had no problems, just got through a lot of propane
Name:	airstream full snow crop.jpeg
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-23-2016, 12:52 PM   #6
Lily&Me's Avatar
Normal , Illinois
What everyone else said.
It's an adventure...get a picture of your Airstream in the snow, and prepare to share your story around a campfire.
Maggie
our maiden voyage nkeeler On The Road... 4 05-30-2010 11:15 PM
Pics From our Maiden Voyage. PIC Heavy. THEPILL 2006 - 2010 International 14 02-22-2010 06:32 PM
Back from our Maiden Voyage!! 71Overlander Our Community 12 03-12-2008 07:35 PM
Our Maiden Voyage! sepezlover On The Road... 1 04-14-2006 09:12 AM
Our Maiden Voyage [Pics] Westfalia Our Community 6 08-01-2005 09:14 AM
