Old 05-08-2002, 11:33 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
small trucks
I am in the market for a small truck, looking for opinions from owners of Toyota, Nissan, Chevy,etc. I am probably going to buy a 95-99 model extended cab, not too optioned, with 2 wd.
Ideas? Also what about using one as a tow dinghy?
Old 05-08-2002, 12:21 PM   #2
1994 30' Excella
New Smyrna Beach , Florida
small truck
I have had several small trucks. the last two were toyota and provided extremely good service. I finally sold the last one with over 340,000 thousand miles on it. No major work was ever done to it. I think it would be just fine for towing light weight loads. I used mine that way. I only had four cylinder engines with automatics and they seemed to perform well above any expectations I had.
Hope this helps.
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 05-08-2002, 01:15 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It does, I am looking at a Toyota now, 97 extra cab Tacoma 4cyl.
Old 05-08-2002, 05:01 PM   #4
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Toyota
Second on the Toyotie. (Texas pronounciation) They are one solid truck. You won't wear it out. After trying, you will just buy another because you want a new one and are sick of the old one.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
Did I ruin my truck's brakes?? Chuck Brakes & Brake Controllers 13 10-14-2002 09:03 AM
Small curbside window davidz71 Upholstery, Blinds, Walls & Interior Finishes 2 09-05-2002 05:09 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
