Old 03-25-2016, 08:50 AM   #1
Sioux Falls , South Dakota
Skin difference?
I've been told that Airstream used a different alloy for the skin beginning in 2000. True?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-25-2016, 09:03 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Not according to a document Airstream published in 2007. Try searching for "history of aluminum at airstream," and you should be able to find the document--I have seen it posted on the forums several times.
The last change to the alloy/thickness was in 1994. Their comment: Airstream widened the body, requiring stronger aluminum for the weight. Side and end panels remained 3003 or 3004-H18 but thickness increased to 0.040 .
The only changes since then have been in the plasticoat supplier.
Old 03-25-2016, 09:13 AM   #3
Thanks. Is there, then, no real difference between late 90's and early 2000's coaches as far as the exterior is concerned? We'll be looking for a 34' coach soon, and think we might be able to go as new as early 2000's, but the late 90's are easily in our budget.
TAC SD-6
AIR 54240
Old 03-25-2016, 09:26 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I think the difference in 2000 was the fact that Airstream started using pre-finished aluminum panels from Alcoa. The EPA played havoc with the emissions from the coatings that Airstream used at the plant in the 90's. There were revisions made through the decade and you will find some 90's models that displayed various forms of premature clear coat peal as Airstream attempted to meet EPA guidelines by changing the formulas that were applied at Jackson Center. I think the later 90's trailers had the most issues. With all the problems, they finally threw in the towel and bought pre-finished aluminum from Alcoa, which if I remember correctly, began with the 2000 models.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-25-2016, 10:19 AM   #5
Thanks. That's what we need to know.
TAC SD-6
AIR 54240
Old 03-25-2016, 01:15 PM   #6
Belegedhel's Avatar
Houston , Texas
I wouldn't make the type of clear coat that is on the trailer a critical decision factor. I have seen trailers as new as 2007 with peeling clear coat. Eventually they will all fail, some sooner than others.
good luck!
« jrank3 | Top | NaCl + Al »
Skin difference? kb0zke 1997 -2001 Excella 3 11-23-2016 10:10 PM
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
What's the difference? IceKing02 1981 - 1983 Excella 0 08-27-2004 11:22 PM
the Airstream Difference Big Dee Our Community 5 01-29-2004 06:47 AM
