Old 01-17-2016, 04:59 PM   #43
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
A lot depends on the weight of the AS.... Our 31' weighed in loaded at 5500#.... Our Z71 4x4 1/2 ton Suburban did awesome- even in the Virginia and upstate New York hills.... Due to needing the space a pu would not cut it - just moved to an Excursion so we can make a few changes (read add weight) to the AS
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 01-17-2016, 05:05 PM   #44
dznf0g's Avatar
Oswego , Illinois
I pull my 30 with a 6.2l maxtow 1500 Silverado. Scooter, 12' inflatable boat, all boating accessories, 10 hp outboard, 2 Honda 2000 genies. Misc stuff on top of that. I am maxed out with that stuff. A Harley most probably puts you in 2500 territory
-Rich-
Old 01-17-2016, 10:56 PM   #45
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Depends on the year of your Airstream but I would go for a Ford F250 and diesel would be my preference. Of course I am thinking about my 30' Classic which can weigh 10,000lbs fully loaded.
TinCan
graysailor is offline   Reply With Quote
Old 01-19-2016, 07:52 AM   #46
2005 30' Classic
Tucson , Arizona
Thanks everyone for your thoughts on this. What we are targeting for our trailer is a 30' 2005 Classic Limited, which I believe has a dry weight of 7,000 and a GVWR of 10000.
It sounds like my situation is very similar to yours. I'm guessing that you've pulled a 10,000 pound trailer with an F-250/2500? Did you notice any lagging on steep inclines?
- Steve
http://www.fulltimeexplorers.com
sdnet01 is offline   Reply With Quote
Old 01-19-2016, 07:58 AM   #47
2005 30' Classic
Tucson , Arizona
Originally Posted by ghaynes755 View Post
3500/350 series, probably a long bed, since you have the motorcycle. If the motorcycle weren't in the mix 2500/250 or other options become available.
We are no longer considering the motorcycle, so that's off the table at this point. We'll just be hauling some cargo in the truck itself as well as pulling the Airstream. So, judging by many of the posts in this thread, it is increasingly looking like a 250/2500 is all that we really need.
- Steve
Old 01-19-2016, 08:02 AM   #48
dznf0g's Avatar
Oswego , Illinois
In that case, I would suggest reconsidering a 1500, 6.2l maxtow. I am extremely impressed.
Cargo capacity of mine is 2034#, tow rating = 11,900#, GCWR = 17,700#. That's a LTZ double cab, regular bed. LT1 option group.
-Rich-
Old 01-19-2016, 08:26 AM   #49
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Our 1995 F250 PowerStroke does a wonderful job of pulling our 1987 Avion 34W, whose GVWR is 9500. Ours is the first year of the PowerStrokes, and is really anaemic in the towing capacity area, compared to PowerStrokes that are even just a few years newer than ours.
I guess what I'm saying is: a new F250 PowerStroke would do a fine job of towing a 30' AS. I would also recommend a gas F250. That would do well, also. The money you'd save on a gas engine could be put towards a LOT of travelling!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-19-2016, 02:50 PM   #50
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Images: 8
Our 2012 Dodge Ram 2500HD Cummins tows our 2014 31' Classic at 19,200 pounds combined weight with no issues both going up and coming down the mountains.
Old 01-19-2016, 03:39 PM   #51
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Here is mine....
Elkhart_Lake_II_05.30.15-8 by Tommie Lauer, on Flickr
2008 Dodge RAM 2500 4x4 Cummins 6.7, modified
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-19-2016, 03:52 PM   #52
TinCan
graysailor's Avatar
2016 30' Classic
sdnet...I have not pulled on any steep grades as yet but I do not foresee any problems in doing that. My F250 feels as though it almost has too much power. Real easy to hit 70mph rather quickly. I do have a high rear end 3.31 so a little slow coming off stop signs and red lights but not really an issue. So far on flat ground I have been getting 12-14 mpg while towing and upwards of 18 when not towing. Speed and wind are always the take aways from MPG.
TinCan
Old 01-19-2016, 08:01 PM   #53
txdxrider's Avatar
Size of truck needed for 31' Airstream?
Having pulled with a 1500 Z71 4X4 suburban- successfully through 16 states and through the smoky mountains - with the weight and size of your trailer go with a minimum of a 2500.. In our situation with three boys and a dog, we needed the Suburban size vehicle. If you don't need the truck you can get a three-quarter ton suburban or an older excursion with the diesel you'll thank me later for the upgraded suspension axles and brakes of the 2500.,,
Old 01-19-2016, 08:25 PM   #54
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I have a half ton, and I have a 27ft Airstream. Therefore I don't feel qualified to answer your question.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 01-19-2016, 08:58 PM   #55
2014 30' FB FC Bunk
Golden , Colorado
We have a 2015 F250 diesel and it pulls our 30' bunkhouse up i70 as fast as we choose to travel. No power issues whatsoever.
bbdo is offline   Reply With Quote
Old 01-20-2016, 06:11 AM   #56
2005 30' Classic
Tucson , Arizona
Thanks. We are looking at a 2005 30' Classic.
- Steve
What size truck or SUV is best? Marinablue Towing, Tow Vehicles & Hitches 265 04-20-2012 11:39 AM
Chevrolet full-size truck/suburban 1999-2006 Jammer Tow Vehicles 11 03-12-2012 08:23 PM
What size truck? boblizzy Tow Vehicles 14 08-03-2004 08:34 PM
