08-04-2007, 04:49 PM
2002 25' Classic
Oro Valley
Should I trash my Sears floor jack?
I have a Sears 4-ton floor jack that will not lift; the jack leaks/squirts oil because of a blown seal, I suspect. The jack is out-of-warranty. I actually only used it about 4 times. It cost me $99 on sale; was supposedly $129 regular price.
Not knowing where to obtain parts or how to fix it or where to have it fixed, shall I trash it? I have my trusty old bottle jack that I used before and now am using again to raise individual wheels of my tv and Jeep to clean the insides of the rims.
What really discourage me was on the Sears.com website I was "shopping" and happened to see the jack. The reviews were actually rants--6 people at least have found the jack to be junk.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
08-04-2007, 05:07 PM
2005 16' International CCD
Ogden
, Utah
Here are a couple of other things to consider, besides trashing the jack:
1) Go to the local auto parts store and buy a bottle of hydraulic jack oil. When you want to use the jack, add some oil. Better buy some rags to wipe up the oil that leaks out, too. I have used jacks like this, sometimes for years - but you have to be careful. I always put jack stands under a car or trailer, after it's jacked up. This is a must-do step if you use a jack that leaks, because it will let the load down - the worse the leak, the faster the jack lets down.
2) This is probably the preferred solution - check the yellow pages for a small repair shop that works on hydraulic jacks. The problem you describe is almost always a leaking seal, and urusally not a big deal to fix for a place that knows jacks and has a supply of seals on hand. My experience is the cylinders seem to last a lot better after they've been repaired, than they do when they are new.
3) The last resort - take it to a flea market or garage sale, and get $20 (or whatever) for it - somebody will want a little-used jack like that. It will be good again after the repair.
But use extreme caution if you must use it while its still leaking.
Good Luck!
08-04-2007, 05:08 PM
2005 28' Safari S/O
Paradise
Sounds like there are now 7 people that found the jack to be junk. I don't know what's involved with replacing the seal on one of those or if it would even be worth it. If it were me I would chalk it up to lesson learned and buy a new one. I have used Craftsman products for years and have had some problems, but most have been able to be resolved. I am wary of Sears (now K-Mart) products now as they are less likely to stand by their product. Even lifetime warranted defective Craftsman tools now need a receipt to be returned.
Steve
"THE OLDER I GET, THE BETTER I WAS"
1972 27' Overlander
Longmont
blown seal
this reminds me of a joke: a guy in far northern Canada, above the arctic circle, comes across another guy working on his snowmobile, a smear of oil in the snow under it. He stops, and asks: "whadja do, blow a seal?" To which the other guy wipes his face and replies "Nah, that's just frost on my moustache!" I know, I don't get it either. Your jack sounds jacked, though.
08-04-2007, 05:46 PM
1967 22' Safari
MILAN
Seal replacement
If you are handy at all with tools (which I'm sure you are owning a A/S) you could take the jack apart and remove the bad seal. Afterall the jack is already out of warranty so you have nothing to lose. There are plenty of bearing/seal companies out there that will sell you a new seal if you have the old one that they can match up with a replacement. Make sure before you remove the leaking seal that you know how it seats into the hydralic cylinder. and how it fit onto the piston. Carefully re-install the new seal and (TahDah) no more leaks. You know you can do this so get the Yellow Pages out and find a local bearing and seal dealer like Timken Bearing etc. NEVER use a leaking hydralic jack to lift anything! You are just courting disaster and possible personal injury or DEATH!!! Hope this helps you out. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
08-04-2007, 06:01 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
it could mean death or worse, damage to you trailer
it is easy to get them rebuilt by a rebuilder. there might be a burr where the seal rides that needs some attention. also, make sure you use jack oil.
08-04-2007, 06:48 PM
Aluminut
2004 25' Safari
If it's Craftsman, it's a lifetime warranty. Have you brought it to the local Sears store?
I would NOT use a jack that is leaking. It's just begging for something to happen.
I have the same jack and totally love it. Have had it for 5+ years. I could lift my car or my truck totally off the ground with it if I could only balance it!
Bring it to Sears and see what they say, if they say no way, then either get a new one or try to find a repair place.
08-04-2007, 07:15 PM
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley
Sears...
Sears will take back or replace darn near anything. it's all in how you approach them, even if you bought it online. no problem.
kevin
08-04-2007, 07:20 PM
2005 28' Safari S/O
Paradise
Sorry Twink, but the lifetime warranty only applies to Craftsman hand tools, like wrenches and screwdrivers, and even that has come under fire since Sears and Kmart merged.
Steve
08-04-2007, 07:25 PM
Aluminut
2004 25' Safari
You may be right....just since the merger, because I use to bring everything but the kitchen sink to them and they gladly exchanged them, no or few questions asked. I would at least ask them before I junked it. Kevin might be right, it's all in how you approach it. The squeeky wheel gets the most oil. Worth a shot IMHO before garbage pickup.
08-04-2007, 07:30 PM
Simi Valley
bring it to simi valley.
i'll exchange it.
kevin
08-04-2007, 08:55 PM
2005 28' Safari S/O
Paradise
i'll exchange it.
kevin
Kev,
Thanks! You da man!
Steve
08-04-2007, 10:11 PM
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
Leaky floor jacks are dangerous! I know of at least one death and of other serious injuries. If Sears won't repair/replace it, and you can get it repaired elsewhere for a reasonable to you fee, do so. Floor jacks are far more practical in most situations than a bottle jack. Of course you always use jack stands as well ( ) so we won't even mention them, as no one would just trust a jack no matter what.
I do not buy cheap jacks from the cheap tool sales guys. There's too much risk of damage to vehicle or body to quibble over a couple of bucks - usually less than an hour or two worth of wages at most.
Replacing seals is no big deal so if nothing else Sears should sell a rebuild kit for you to use. As noted, check for the reasons the old one went away. And always store your hydraulic jacks with the seal tight, not loosened off.
Let us know how you make out.
Barry
08-04-2007, 10:33 PM
Simi Valley
drive to sears.
exchange floor jack.
drive home.
camera pans out.
hi!, i'm home!
wild cheers....
cut to commerical...
08-04-2007, 10:36 PM
2002 25' Safari
Dewey
This plan is better:
Drive to Phoenix
Drop it off at my house
I'll dispose of it for you
No charge
Richard
08-04-2007, 10:39 PM
Simi Valley
True Blu... FFA Buddy...
Drive to Phoenix
No charge
richard,
your tru blue
and
green
all at the same time...
i might just buy a sears floor jack so i can show up at your door step to drop it off.
kevin
08-04-2007, 10:59 PM
2002 25' Safari
Dewey
kevin
That would be great. Jan does not like the setup I have now, she does not think it is safe ....
Richard
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
All's well that ends well. I really like the joke about the guy under the snowmobile. I guess that shows my mind is in the gutter.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
08-04-2007, 11:02 PM
Simi Valley
Hillbilly Jack System...
mr caster,
as the lead inspecter for OSHA here in the southern part of the other part, the Hillbilly Jack System is time honored and considered to be quite safe from an OSHA point of view.
flat man
08-04-2007, 11:05 PM
2002 25' Safari
Dewey
Now I get it! It took a while, but when you mentioned mind in the gutter, the light turned on.
Thanks!
Richard
