Old 03-21-2019, 01:29 PM   #1
Los Angeles , California
Should I pull the trigger on this used airstream?
Hi everyone, I'm new to this forum and am currently on the hunt for a used 25' front bed twin airstream travel trailer from the last 10-20 years. I found one that fits the bill, but I am concerned by the fact that it seems to have a lot of rust in the undercarriage, which is surprising because it is a 2017 model. Also there is a slight, perhaps 2 degree, bend in the long square tube that I assume is the axel. The bend is evident in person, but not so much in pictures.
Please take a look at the attached pictures and let me know if you think the rust under the trailer is not a big deal, or if it will cause major problems in the future.
Also, if anyone has any leads on other uses 25' front bed twin airstreams, please let me know!
ID:	336236   Click image for larger version
ID:	336238   Click image for larger version
ID:	336240   Click image for larger version
ID:	336242   Click image for larger version
ID:	336244   Click image for larger version
Faja is offline   Reply With Quote
Old 03-21-2019, 01:39 PM   #2
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Does not look like any structural damage, but normal corrosion. I see you are in LA - in northern California this dealer is well respected as having good quality trailers.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 03-21-2019, 02:12 PM   #3
2007 22' International CCD
The slight bend in the axle is used to align it. Normal.
Old 03-21-2019, 02:31 PM   #4
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Perhaps it was an East coast trailer and ran on salted roads.
I just peeked under my 2017 and the only rust is on the bottom of the stabilizer pads.
SilverWind is offline   Reply With Quote
Old 03-21-2019, 02:41 PM   #5
dznf0g's Avatar
Oswego , Illinois
Does appear to me to be normal road salt corrosion. It is time for some maintenance down there. A thorough washing, wire brushing and a coat of paint on the frame and axles. Looks superficial at this point.
As said the bend is normal. The camber and toe-in are set by physically bending the axles slightly while on a trailer alignment rack.
-Rich-
Old 03-21-2019, 02:45 PM   #6
2013 20' Flying Cloud
Westerly , Rhode Island
Really depends on the price. There are lots of 25FB out there to choose from and personally I would not pay the typical price of a used 2017 with that much rust already. Our 2013 has virtually almost none.
smithcreek is offline   Reply With Quote
Old 03-21-2019, 04:51 PM   #7
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Our 91 trailer has less rust. Probably not a big deal but guessing your in the $60K + range I would look for a nicer one.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 03-21-2019, 08:23 PM   #8
dznf0g's Avatar
Oswego , Illinois
Yeah, you live in California. One day on a wet salted road and that's what you see the next spring. It os entirely normal for any AS used in winter. Not sure where OP lives, but get used to it.
-Rich-
Old 03-22-2019, 09:12 AM   #9
1996 25' Excella
Tillsonburg , Ontario
That rust is normal for any AS that has seen some travel. I would have expected that.
I believe the axles do have a slight bow which is original to the Dexter axles. Serious damage shows up as a dent or uneven curvature on one end.
The pan is quite clean, so it has not seen any long term exposure to salt from what I can see from the pics.
What is the exterior finish like?
JCW
JCWDCW is offline   Reply With Quote
Old 03-22-2019, 11:20 AM   #10
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
The axles are designed with a slight arch. Most all trailers are like that, from utility trailers to Airstreams.
jimfa440 is offline   Reply With Quote
Old 03-22-2019, 11:31 AM   #11
AlinCal's Avatar
1991 25' Excella
The OP is from Ca too and why go get a rust bucket to bring back?
Wondering what the
Will Rogers
Alan
Old 03-22-2019, 11:51 AM   #12
I'm in RI and we bought our trailer from a woman in MA, we know our salted road pretty well! From the lack of rust on our frame and running gear, our trailer though has apparently never seen salted roads.
Is that trailer about to fall apart? No. But if I had two 2017 FC25 trailer to choose from and one had rust from salty roads and being stored outside while the other was stored indoors every year before winter hit I know which one I would choose. There are lots of FC25s to choose from.
Old 03-22-2019, 12:39 PM   #13
AlinCal's Avatar
1991 25' Excella
Wondering what the
I guess I cut myself off...Wondering what the clearcoat looks like in terms of corrosion?
Some of the trailers I've seen here that spent their life around the ocean have had seriously ugly filform corrosion.
Will Rogers
Alan
Old 03-27-2019, 01:00 PM   #14
2010 25' FB International
Livermore , California
I agree with this wholeheartedly; after many years in Michigan and then many more in California, I can say that wrenching on a vehicle that has never seen salt is now an imperative for me, and was a serious consideration when searching for our AS.
...and also 2nd the recommendation upthread to talk to Vincent at A to Z Motors.
MotoMannequin is offline   Reply With Quote
16 Ft Bambi Questions - About to pull the trigger zimode 2005 and newer - Bambi all models 35 05-10-2017 06:26 PM
Should I pull trigger? - 1960 22' Tailwind teleguy Trailer Values 23 03-01-2013 04:12 PM
about to pull the trigger Snedwid Member Introductions 4 05-04-2010 11:38 AM
About To Pull The Trigger On A 2002 Ford F350 XL 7.3 Turbo Diesel Yhottys Tow Vehicles 22 04-28-2010 10:10 AM
about to pull trigger '74 Sovereign Intl patis General Repair Forum 18 03-08-2010 02:32 PM
