Old 04-21-2014, 07:02 PM   #57
2010 16' International
kittery , Maine
Adding another component to the weight list: I removed the upper cabinet above the galley. It was pretty easy to do. Snipped the 2 wires for the single halogen light at the base of the cabinet and installed wire nuts for now. The lights inside the cabinet (on the ceiling) are actually mounted in the finished ceiling of the trailer, so I didn't need to mess with them. This cabinet weighs 28 lbs. I'll install a simple, single wireframe shelf (the look should blend nicely with the existing interior), and I'll affix the range vent/light unit underneath, just as it was on the cabinet. Shelf will be supported at the rear with 4 screws, and at the outermost part of left/right edges (left, screw into closet wall; right, screw into the forward cabinet). Should weigh only several pounds and be very stable. If I change my mind, it can easily go back to original.
Feels a lot roomier without the cabinet.
Just looking down the list at the easy stuff, and estimating weights of the replacement items where applicable (steel spare wheel replaced w/alum; auto jack replaced with manual; etc.) I'm seeing a savings of about 300 lbs. Not bad. As others have mentioned, if it gets too light, the suspension might be too stiff and the trailer would end up bouncing around.
100# (estimated, not weighed) - air conditioner (replace w/Fantastic Fan?)
28# - upper cabinet above galley (includes sliding doors, does not include vent/light unit)
37# - Steel 20# LP tank, full
17# - Steel 20# tank LP, empty
54# - Corner seat at rear (the one with drawer underneath. This includes empty drawer, seat cushion, and 2-piece back cushion.
23# - mattress (replace w/air mattress and/or foam?)
10# - flat panel TV (removed from arm, without arm or stand)
8.5# - subwoofer behind rear corner seat
23.5# - electric jack (replace w/manual jack)
53.5# - spare wheel (steel rim and Goodyear Marathon ST225/75R15 tire) (replace w/alum wheel)
amm3824 is offline   Reply With Quote
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
Anyone towing 5,000 lbs with a V8 BMW X5? adwriter73 Tow Vehicles 20 06-17-2010 01:14 AM
Diesel Chevy, Ford, Dodge, or GMC?! 10,000 lbs NomadKitchen Tow Vehicles 12 10-16-2009 09:01 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
28,000 or 128,000 miles? jimelmoreiii Mechanics Corner - Engines, Transmission & More... 8 01-11-2004 07:16 AM
