Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 12-01-2002, 07:43 AM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Shakedown trip--holding tank draining quest.
I am continuing to explore what is "normal" for different parts of our Airstream.....
Wash is grey water; Main is black....right. When I dumped the black (test panel showed 2/3 full) it did not rush out???? Do you suppose it is clogged. This was the first time it has been used. After waiting the level on the test panel for the main tank went down to 1/3. Then I flushed with the grey and I could hear that.
I also used the flush system on the main tank after that. I have heard of mfg.s leaving the cutouts for the drains in the tanks...do you think I got "lucky"?
Kistler
Kistler is offline   Reply With Quote
Old 12-01-2002, 07:59 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
If you open the valve on the toilet you can see in the black tank and get an idea of the actual level.
John
74Argosy24MH is offline   Reply With Quote
Old 12-01-2002, 09:55 AM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Dumping black water
Level gages aren't always accurate, especially in black tanks.
You should normally see the hose "surge" when you open the black valve, so much so that it is best to make sure the other end of the hose is well secured (I made that mistake once, years ago). It shouldn't take more than a minute to dump the black tank.
I always stand on the flush pedal for a while to put extra water in the tank before dumping. I do this while still hooked up if not on a full hookup. As 74Argosy24MH said, you can see the level in the tank with the valve open. You can't have too much liquid in the tank.
I also have been known to make an extra loop around the campground to slosh the tank before dumping. This helps get the solids moving.
It wouldn't hurt to open the valves and poke a garden hose in there to see if you hit any obsruction.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 12-01-2002, 10:10 AM   #4
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Unhappy Shake Down Cruise
Kistler, was the drain hose leaving the valve in a downward position? Was the valve completly open? Any restriction in the hose or the sewer connection? Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 12-01-2002, 10:18 AM   #5
Kistler
Kistler's Avatar
Thank you all for answering....the hose sloped down and had no restrictions.....possibly the gauges are off and it wasn't that full.
We were reallly accustomed (after nine years) to our old Jamboree and its idiosyncracies One interesting thing I noted was that the Valera (sp) brand black coupling would not fit the Airstream's white coupling; luckily the dealer had sent a white fitting that coupled nicely.
How well does Airstream's "clean out" by attaching the shore water really work. On my old rig I had a special hose for going in the people door and putting down the stool; then I was really sure we were cleaned.
Kistler
Old 12-01-2002, 10:19 AM   #6
John
Profile:
additional thoughts!!
Kistler,
Do you have the "black water tank flush" in your trailer? If you do, after dumping your blank tank, refill it via the "BW tank flush" and then drain it again. I do this when ever I have water available to help prevent build-up of waste.
Also, you should always leave a few gallons of water in the "black water tank" to prevent solids from drying out and clogging the drain.
John
John is offline   Reply With Quote
Old 12-01-2002, 10:21 AM   #7
Kistler
Kistler's Avatar
Yes, it has that flush thing. I'll use your method.
Kistler
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 08:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 12:03 PM
Holding tank plumbing question yukionna 1999 - 2004 Bambi 15 09-10-2003 09:00 PM
Front Holding Tank Leak Deejay Fresh Water Systems 0 07-08-2003 08:29 AM
