Old 03-11-2010, 09:26 PM   #15
Ottawa , ON
What about travelling with rabbits?
How often does the litter have to be changed? Is there a MPC (miles per carrot) issue?
Old 03-11-2010, 10:10 PM   #16
1988 32.5' Airstream 325
calgary , alberta
well I have to add some thoughts from first hand experiance! Fisrt of all there a least 50 to 1 car and truck fires than rv fires! Many rv owners don't seem to understand the term maintenance! The units wheather towed or under ther own power roll along the road twisting, turning and bumping around and loosen up fittings rub wires bare and create problems these units need constant upkeep and care! Then you have the folks who leave thier pilots on when refueling! how about the units over loaded to the nines causing over heated brakes and tires not to mention checking lug nuts! Turn off your propane and disconnect batteries in storage! If you have a problem get it fixed by a pro not by a backyard mech just to save a dollar, 30 years a pro fire fighter I've seen it is usually a human error that that has started the fire, and don't waste your money on sprinklers in your home!!!!! Invest in your local fire depts!!! be HOME SAFE... no open oil cooking no smoking in your home Don't overload or use extention cords!! SMOKE DETECTORS AND HOME MAINTENANCE!! THE CAPTAIN SPEAKING
jhenry is offline   Reply With Quote
Old 03-11-2010, 10:43 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
RV fires.
Hi, I think RV fires are, or could be, very similar to house fires.
(1.) Cigarettes
(2.) Candles
(3.) Cooking accidents.
Maybe not necessarily RV related, but how many times have you heard that somebody, on oxygen, fell asleep, in bed, while smoking?
I think the basic RV is safe; People are dangerous!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 03-12-2010, 06:07 AM   #18
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
Originally Posted by Aage View Post
What was it, a 25-footer?
I don't want to hijack this thread and make it all about my example, but I do want to make sure people know it was not an Airstream. It was a 2007 Keystone Laredo 26RK and the fire was in December of 2007.
Steve
TinLoaf is offline   Reply With Quote
Old 03-12-2010, 06:55 AM   #19
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Along the lines of PM, shake or invert and pound your fire extinguisher, if the powder isn't loose you only get one small puff of air to blow out the flame. You can feel the flow of loose powder in a new one. When I opened the old one powder was caked. I was lucky, it was enough to extinguish a burning wire connection with a 3 inch flame.
Old 03-12-2010, 07:05 AM   #20
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
When we got our '83 Sovereign last year, I went over with the kiddos (ages 9 and 6) how to operate the emergency exit window in the back. We review "what do you do in a fire" type scenarios. Guess I should do that again at the start of this season, too! Also have the fire extinguisher in the galley and a combo smoke/CO alarm in the hallway.
Alsupp is offline   Reply With Quote
Old 03-13-2010, 04:47 AM   #21
calgary , alberta
Dry chem extinguisher.. what happens is that powder settles at bottom so turn up side down and then gently hit the side also make sure needle is not indicating recharge but is in the green also check your detectors new batteries in spring!
Does anyone else hate camp fires? Wayne&Sam On The Road... 573 05-02-2014 06:43 PM
New NT-30SP fires 10 sec. then goes out, fan on fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2009 07:04 PM
Dometic Refrigerator Fires? Cracker Refrigerators 89 07-27-2008 04:59 PM
Florida Fires Devoman Off Topic Forum 8 05-16-2007 06:16 AM
Temecula (Corona) California Fires Cat Off Topic Forum 3 05-08-2004 10:56 AM
