Old 09-08-2003, 08:50 PM   #1
TOM CRUMP's Avatar
1970 27' Overlander
Braxton , Mississippi
Images: 26
Roof Air
I did a lot of research when I had to replace the A/C in my 31' International, I chose the Carrier 15k BTU from www,rvsupplywarehouse.com priced at $649 shipping included. It was a bear of a job swapping out the old Armstrong, it took 3 of us 5 hours. The results: I'm pleased with the performance, it runs very quite, the only downside is the unit has no drain pipe connector, condensation is slung on the compressor, any excess runs off the roof. Note this is not a low profile unit.
TC
TOM CRUMP is offline   Reply With Quote
Old 09-09-2003, 05:52 AM   #2
Don in E Texas's Avatar
Tom:
I have the same a/c unit installed on our 31' Airstream. Installed on the original pan. Water goes via 'tube' just like original a/c unit. I've had no problems with our unit ---- no leaks, etc.
Don
Don in E Texas
Don in E Texas is offline   Reply With Quote
Old 09-09-2003, 06:15 AM   #3
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
Re: Roof Air
interesting ...using condensate to cool the compressor....usually units are designed to not pick up too much superheat(the refrigerant)....leaving some cooling effect for the windings...i have some misgivings on how good this arrangement is...some years ago window shakers used to have a slinger type fan blade that would direct the condensate onto the condensor coil.... maybe that is what you have...Carrier has done some nutty things in the past...hope this unit performs for you...good luck..
norby
p.s.spraying condensor coils is not very effective in high humidity areas...
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
2004 30' Classic roof rack gklott Our Community 0 07-15-2003 03:00 PM
Roof question Don in E Texas Roof 2 02-21-2003 06:11 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
