10-04-2016, 12:03 PM
#141
2012 25' Flying Cloud
Battle Lake
Posse, there are Jeep GC rated to tow over twice the 3500 its you mentioned, and excellent fully independent suspensions to keep it all going straight. This Jeep GC suspension was designed by Mercedes, nothing like the solid axle great off-road genuine Jeeps. The Jeep name here is a marketing thing, Dodge Durango uses the same setup in a little longer wheelbase.
Nonetheless, the accident was caused by very heavy weight hung back over the back of the Airstream, it could have taken anything off the road. Proper loading matters, heavy weight near the trailer axles, light weight at the ends, at least 10% on the hitch.
Doug and Cheryl
10-04-2016, 01:15 PM
#142
1995 34' Excella
Cochrane
, Alberta
Bottom line. Did insurance pay out?
10-04-2016, 03:15 PM
#143
1972 25' Tradewind
North Vancouver
, British Columbia
Originally Posted by GCinSC2
I saw a small rental trailer wagging the dog just like that demo. I safely passed it only to later catch it in my mirror violently swaying and then rolling over into the median.
Respect physics even if you don't understand it.
Were the occupants okay?
North Vancouver, BC
10-04-2016, 05:56 PM
#144
2007 30' Classic S/O
Somewhere
, South Carolina
Occupants, unknown. I was well ahead of the incident and there was plenty of traffic following. Backing up was not an option. But the look of the hitch going L-R-L-R in a swaying motion and the hitch was higher, had the trailer tongue above level on an unknown SUV just looked like an uncomfortable situation.
10-04-2016, 07:35 PM
#145
2009 34' Classic
Lake Worth Beach
Originally Posted by Posse96
My immediate thought is, the max towing of all Jeep models currently is 3,500 lbs, per the spec sheets.
Incorrect. The Jeep Grand Cherokee has a base tow rating of 5,000 lbs, and properly equipped from the factory, up to 7,400 lbs. This has been the case at least since the 2005 model year.
In fact, the JGC is an excellent tow vehicle. I used a 2015 JGC to pull my 25 FB across country....it was a pleasure to tow. The only issue is payload - it just doesn't offer enough payload capacity to allow much more than a driver, passenger, and the trailer. That's a convenience issue, not a safety issue - you have to respect the weight limits, which means you have to leave stuff home. But loaded properly, it's a safe and comfortable TV.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
10-05-2016, 07:35 AM
#146
Biloxi
, Mississippi
Jim, I was going to comment on that incorrect information but you beat me too it.
MICHAEL
10-14-2016, 06:38 PM
#147
Lakes Region
, New Hampshire
Just watched this video, while the craftsmanship is to notch and the video is really well done, I wonder how much of an issue he has created for himself. If you look at 8:18 in, it doesn't look very light and I imagine adding some high end bikes will only make it worse.
https://youtu.be/Zzpwm7fVZts
At least his tow vehicle looks like it can handle it, somewhat.
08-20-2017, 08:52 AM
#148
1977 31' Excella 500
Dallas
I believe we require an apology by the Canadian minister over transportation for a couple of Yahoo's destroying USA WORK PRODUCT.
08-20-2017, 02:08 PM
#149
2017 30' International
Broomfield
Rollover in Quebec
I'm going to guess that the receiver added 75lbs, hitch added 50lbs and 2 carbon mountain bikes added 50lbs. So that's 175lbs aft of the trailers axle. Not far off from installing lithium batteries and locating under the rear bed...
08-20-2017, 03:32 PM
#150
Ottawa
, ON
I agree with Davidson Overland: the injuries were minor, not the people.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
08-20-2017, 04:06 PM
#151
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Unless there's info on what actually *was* in the "big gray box" .... hard to tell what impact it had.
It would be nice to hear from the poor people in the TV ....
10-04-2020, 06:21 PM
#152
redding
That AS should not have been pulled by a Jeep. Doubt it would have happened with 3/4 OR ONE TON TRUCK PULLING IT. Would like to know the experience of the driver and speed when towing!
10-04-2020, 08:37 PM
#153
2019 22' Sport
Port Coquitlam
, British Columbia
There are some obvious questions about how the weight was distributed. Adding the bike rack box on the back certainly would be a factor to increased sway. The type of hitch would also tell part of the story. Mechanical failure of the Jeep or tire blow out would be possible or perhaps an animal darted out or another car cut the driver off. Inexperience could play a factor. In looking at the pictures of the road, it looks pretty straight. Maybe gusty cross winds came up.
I was not able to read all the posts but I suspect that the explanation may have been noted in one of the posts.
Opening up the ongoing debate about tow vehicles is what will happen here.
Does the Grand Cherokee have the ability to tow a 6,000 lbs trailer? I think Chrysler would say yes! What sort of effect did the bike rack have on the tongue weight making it too light to offer the ideal 15%? contributing to sway which might have lead up to the roll over. Did the driver have any sway control at the hitch?
Lots of questions on my part...
Peter.
"Live Long and Prosper \\//" - Spock
10-04-2020, 08:39 PM
#154
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Hi, folks, just an FYI, this is a Very. Old. Thread.
10-04-2020, 08:44 PM
#155
2019 22' Sport
Port Coquitlam
, British Columbia
Nothing beats digging up the old news and beating it up again!
Peter.
10-04-2020, 08:49 PM
#156
1977 31' Sovereign
Sunset Valley
Since it’s been revived, isn’t it fresh again?
Personally, with all the new influx of RV’ers, I’m glad this topic has come up anew. In the last several months, I’ve seen some downright stupid rigs on the road, hopefully some folks can still glean something out of threads like this.
Just saying...
Ian
10-05-2020, 01:34 AM
#157
Sag Harbor
, New York
Plenty of good info here, still, and an opportunity for newcomers to learn, including the ability and wisdom to read all of a long thread, and to separate wheat from chaff.
A similarly long read -- and also a good learning experience IMO -- is the " Out of control sway" thread. [hot link in blue]
Happy trails,
10-05-2020, 08:21 AM
#158
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The basic questions are still open three years later. That's pretty typical in these threads. You have a limited amount of data and a whole lot of guessing. There's never a "reveal" to show you how close the guesses came ....
10-05-2020, 08:34 AM
#159
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
A new forum rule?>>>>>If you don't know the answer, don't proffer a response.
Well, that will never fly.
10-05-2020, 08:57 AM
#160
Sag Harbor
, New York
Originally Posted by ROBERT CROSS
. . . Well, that will never fly.
Ya think?
