Old 07-21-2016, 01:11 PM   #85
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
You can tow anything with anything and any kind of hitch and any kind of weight distribution. As long as everything is going well.
The more things that you have that make your rig unstable, the fewer things (outside influences) it will take to put you on your backside.
Me - I prefer to run with as stable a lash-up in as many ways as possible. Then there will be some forgiveness if I become momentarily inattentive, someone causes me to react too quickly or something else out of my control presents itself.
From all appearances, the rig pictured here needed everything always to go according to plan.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 07-21-2016, 01:29 PM   #86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Rollover in Quebec
Originally Posted by SteveSueMac View Post
I don't know for certain - but I can't imagine even a VPP hitch would overcome something like that "shed" on the back of a trailer.
Lol, there certainly are limits.
That box could have upwards of several hundred or even a thousand pounds or better in that box.
The box has a capacity of over 60 cubic feet. Filled even with clothes and linens it could contain 600 pounds easy enough.
Gradiens super tenui glacie.
Old 07-21-2016, 01:51 PM   #87
Long Island , New York
Plus when you square the increased distance rearward away from the center of gravity of the trailer, any such large mass takes on a new forcefullness . . .
Old 07-21-2016, 02:20 PM   #88
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
[QUOTE=PKI;1824223]AW - a thought - looks like the JGC may have 265/60R18 tires fitted. It appears that LT255/65R18 are similar in diameter. Would appreciate your thoughts and those of Andrew on the value of going to LT tires for the SUV towing application. Also, any thoughts on the stiffer side wall run flat tires. This is a bit of a hijack, but an important element of consideration to achieve stability. Appreciate your input. Pat
Pat, I have 20 inch wheels and have Bridgestone Dueler H/L on my Jeep in size P265/50R20 106V. They were recommended to me by a close friend that has been in the commercial tire business for many years. I did not buy them from him so there was no ulterior motive for his recommendation. They are comfortable, well riding, long lasting tires. I have had them for just over two years. Unlike some here I do not pretend to be an engineer of any kind so can only base my opinion on actual use and seat of the pants feel. I like them and that is all that matters. (For the benefit of any one that wants to criticize my choice)
MICHAEL
Old 07-21-2016, 02:22 PM   #89
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by OTRA15 View Post
There is an active thread on that topic:
-- snip -- And PLENTY of tire threads! -- snip --
Thanks for the links. Generally the primary thread has lots of info on the success folks have had towing with the JGC and there is also some hitch info. There does not seem to be a lot of detailed information on how to improve the stability of the JGC. Hoping these questions can expand the discussion.
This incident certainly has more information that prior rollover incidents and that contributes to an understanding of the forces in play and the viable solutions necessary to control them.
Pat
Old 07-21-2016, 02:29 PM   #90
PKI
PKI's Avatar
-- snip -- P265/50R20 106V. -- snip --[/QUOTE]
AW - yes, the low profile approach. May turn out to be better in the long run.
Thanks - Pat
Old 07-21-2016, 07:16 PM   #91
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Originally Posted by DanB View Post
First off, I don't disagree that the setup was poor and the box was a bad decision.
I am simply saying that we are completely grasping at straws as to what happened. Unless I missed it, the news report does not indicate ANY cause.
For all we know, it may have been an unavoidable situation caused by an outside force. Until the police report is made public, I won't be sure about anything.
Told ya. Dealing with facts is not enough, not even with proof. I think everyone agrees that many factors could have been the cause. What was in the box? Was it full? Was it empty?
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 07-21-2016, 07:36 PM   #92
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Any more in the weeds, and this post gets ticks.
I personally recommend, for safety sake, pull your AS with an International 4700 modified stake truck with a 32k GVWR, or if you're on the cheap, a F-550 crew. My attorney says I should, for safety's sake, wrap myself in foil and not breathe. He's the fiduciary.
As AW said, let the speculative entertainment continue.
14 Serenity 28'
15 Grand Cherokee EcoD
#5261
westernjeep401 is offline   Reply With Quote
Old 07-21-2016, 07:54 PM   #93
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Looks like the Komo carrier is pretty heavy.
(or is the weight spec the capacity?)
http://www.ecarriershelving.com/?category_id=31
Alan
Old 07-21-2016, 08:07 PM   #94
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
For whatever it's worth, none of the 3 pics on their website have the unit hanging off the back of a trailer - all are connected behind the rear axle of a self contained vehicle not hitched to anything else.
Old 07-21-2016, 08:08 PM   #95
white laker's Avatar
2008 34' Classic S/O
lanark , Ontario
and you wonder why?
Pete Crook
"Put it all behind you!"
S/OS#88
WBCCI # 8160
white laker is offline   Reply With Quote
Old 07-21-2016, 08:09 PM   #96
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I think it has the swing out add on option or a ramp/carrier, mentioned somewhere when I looked at other models on that website.
But, I am speculating. I do not know since I've never seen one of these before.
Alan
Old 07-21-2016, 08:17 PM   #97
W , New England
Originally Posted by white laker View Post
and you wonder why?
Nope. 😀
Old 07-22-2016, 05:26 AM   #98
If the Komo box weighs any more than the AS-approved Fiamma bike rack at about 92 lbs. including bikes, it is not within the Airstream design specs.. Ditto for the approved location -- basically above the rear bumper, with the bikes just barely aft of the bumper.
End of discussion.
Period.
One can kick and scream about Airstream's strict limits . . . but . . .
Acceptance of limits is one of life's hardest lessons IMO, not only for spoiled brat children, but also for many adults.
"But I know better . . . "
"I Want it . . !!!"
NEU 064 : Magog-Orford Quebec joint rally NEU/Quebec golddigger WBCCI Rallies & Events 1 05-18-2012 11:38 AM
YouTube clip of Airstream Rollover Road Ruler Towing, Tow Vehicles & Hitches 2 07-05-2007 02:14 PM
'01 Bambi rollover at Colaw for parts Creampuff Exterior Restoration Forum 0 11-16-2003 07:52 PM
The ultimate disaster - Airstream rollover ipso_facto On The Road... 44 05-07-2003 01:01 AM
