02-24-2003, 10:07 AM
2002 25' Classic
Kalama
rivets
Can someone give me some info or direct me re rivets w/brand name Olympic? I read a post in the last two weeks that referred to them in mounting solar panels -- saying they were preferable to pop rivets for a number of reasons. Anyway, I'd like to learn about them and where to get them. Thanks in advance. Brian
02-24-2003, 10:44 AM
Brian try this company: http://www.bylerrivet.com/
They have bin very helpfull to me. Very fast service
alex
02-24-2003, 01:28 PM
New Borockton
, Alabama
Ive been selling them for quite awhile for $19.75 per 100 with the neoprene washer. Not sure if that's the best price out there, but I think it is. The best thing going is the Flipper rivet tool by the same company (Gesipa) that makes the rivets. 40% less effort than a standard manual rivet setter.
Randy
02-24-2003, 11:53 PM
2002 25' Classic
Kalama
rivet, rivet
Alex, Chantal, Randy ... many thanks. Just what I needed!
Randy -- Is there a phone#/time I can reach you?
Brian
02-25-2003, 06:20 AM
New Borockton
, Alabama
334-347-2063 anytime. If I miss your call, leave your number and I'll call you back.
Randy
02-25-2003, 09:57 AM
Corona
It "is not" recommended to use olympic rivets with washers.
Reason.
The washer do not last forever. They will dry out which in turn will allow a water leak. Not just one here or there, but all of them.
If the factory wants to use them, that's fine. They have to warranty the repair.
Place that repair in the hot desert, and watch what happens, very quickly.
A far superior way is to use regular olympics, and vulkem sealer.
Run a small bead of vulkem on a metal plate. Turn the shank of the rivet, just below the head, into the vulkem. This will put a small circle of sealer underneath the rivet head. Insert the rivet, and install it. Any excess sealer can easily be removed.
We all know that vulkem is almost ageless. Additionally, it will "NEVER" harden or crack. Therefore, it will never leak.
Using the washer type olympic, is a short term fix, that is less than an optimum repair.
We have replaced thousands of the washer type, that were causing rain water leaks.
Beware of what seems to be an "easy" fix. It won't hold water, over time.
I know, I know, there are the washer believers. But the test of time, says otherwise.
inlandrv.com
airstreamparts.com
airstreamcandy.com
02-25-2003, 10:29 AM
New Borockton
, Alabama
Yes, I can see where in dry enviornments, that could happen in time. I use both washers AND vulkem and haven't had any problems. I also remind people that the washers are easy to remove if you prefer not to use them on some areas of the trailer and do on others.
Randy
02-27-2003, 11:50 AM
2002 25' Classic
Kalama
to wash er not to wash
Andy -- Good info, thanks for chiming in.
Brian
02-28-2003, 11:34 AM
2004 28' Classic
huntsville
, Alabama
thnx andy
i have a small leak and i think i know which river that needs replacing with vulkem. was going to use the rubbergasket. lol
al
02-28-2003, 01:13 PM
1979 24' Airstream Excella 24
Adams
, Tennessee
What if any is the shelf life of vulkem. I have heard that it has a shelf life of about 90 days is this true ? Is it the best sealer to use to stop leaks?
02-28-2003, 03:49 PM
Corona
The shelf life of any sealant is a function of the environment that it is kept in. If kept cool, vulkem will last a year or better, on the shelf.
inlandrv.com
airstreamparts.com
airstreamcandy.com
07-09-2003, 06:10 PM
rivets
I just replaced three sections of the front of my Excella,I used 400 olympic rivets and 1 tube of Parbond, bought all the supplies from inlandrv and Andy hooked me up, its nice to deal with somebody that knows his stuff! Thanks Andy!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tiny Rivets
Chuck |
Ribs, Skins & Rivets |
6 |
11-28-2015 10:39 AM |
Who needs Rivets???
05ModPod |
On The Road... |
3 |
02-18-2004 02:28 PM |
Missing Exterior Rivets
carls017 |
5 |
10-13-2003 08:55 AM |
Rivets Again
davespann |
3 |
08-03-2003 05:07 PM |
Rivets
skip |
25 |
08-03-2003 10:46 AM |
