Old 09-09-2013, 08:05 AM   #1
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Rivet Members
I've been on Air Forums for a while and still confused about a few things. What is a Rivet Member and how does one get rivets?
kswelsh is offline   Reply With Quote
Old 09-09-2013, 08:09 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Rivet "status" is achieved by posting to the forums--sort of a way to recognize active participants. So, the more you post, the more rivets you get, topping out at 5, I believe.
Old 09-09-2013, 08:14 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The reason you don't see your rivet count is that you entered the value "2NCan" in the "Custom user title" field under "Edit Your Details" in the user control panel. That overrides the default rivet count. You should be able to see what your rivet count is on that same page, and if you want to show it, just check the reset box and save changes.
David
Old 09-09-2013, 08:27 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
From our Forums 101 thread -- more on the rivet story:
http://www.airforums.com/forums/f138...tml#post613497
http://www.airforums.com/forums/f138...tml#post613554
You also saw some gold rivets around Janet's username & avatar area in these posts I linked -- those come from making a $20 annual donation as noted here. Full forum participation is welcome with or without this donation. We sure appreciate our willing supporters though.
5 meter Langford Nahanni
