The dealer we bought our trailer from was going to "trade up" from the friction control sway installation to the dual cam BUT discovered that the bracket would necessitate moving a propane line.
Apparently, our warranty from Airstream would be voided if such changes were made so am stuck.
They bent the lever on the friction bar so that I can turn it; prior the propane tank cover had to be removed OR my wife would have to walk along side the trailer hitch as I drove forward AND try to remove the friction bar when it loosened.
This method (walking, trying to wiggle it off) is/was very unglamorous if not downright degrading.
I tried to get a dual cam and the dealer was willing. Doesn't Reese build anything for Airstream? How did you all install the dual cam?
I can understand your problem. I was extremely lucky in that my existing Draw-Tite hitch was dimensioned just perfectly to place the hook bracket in the only possible place that it could be mounted on the A-frame. The bracket can not be moved an inch in either direction. If the spring arms were two inches longer or shorter, I would have been out of luck.
What I don't understand is the warrenty thing. On automobiles, the warrenty holds good so long as the modification or new part does not cause the problem. Seems like that should apply equally to the A/S.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Guess that you do understand the prob....A frame has a propane line under it and the dealer didn't wish to work (modify) with that and I can understand....I am really afraid of propane anyway...
What gets me is that Airstreams do exist and Reese hasn't (or Airstream) doesn't see the future of hitch/trailer adaptations...
The gas line is held up to the bottom of the A-frame by a coupla clamps riveted to the bottom of the A-frame tube. So you can't put any kind of U-bolt on that side without the plate crushing the gas line.
One drill bit, 10-15 seconds and the heads of the rivets are gone.
The gas line drops down an inch or so, the plate goes in, and with the gas line running between the ends of the U-bolt, you can use any manner of things to resupport the gas line, including the original clamps held down with a spacer between them and the frame and a long screw to replace the rivet, or a soft support between the U-bolt ends.
The gas line is on the bottom of the A-Frame -- saw it-- (why does that seem like bad English) They didn't wish/want to change it...understand sorta.....flexible for about 2 inches and then was on the bottom of the A-Frame...right now in the way of the squeezing of the ____ part of the u bolt.
Do I have some sort of quarantee from Jackson ???? was that an excuse from the dealer? will we die because we didn't get a dual cam?
is that the dealer just didn't want to do it and the warrenty thing is a smoke screen.
I agree with Maurice, it is something that would take me about 10 minutes in my driveway. You should be able to tow it carefully to a hitch installer who, I'm sure, would do exactly what Maurice suggested.
John W. Irwin
Airstream warrants the trailer. If your air conditioner leaks they aren't going to deny you warranty service on that because you remounted the gas line an inch lower. Even if your gas regulator quits working, they aren't going to deny you warranty service on that. If the remounting causes something to rub a hole in the gas line, then yeah, they wouldn't warrant that... but it would have to be a pretty poor job of remounting it.
Doing this won't stress the gas line... it's soft and bendable anyway.
BTW, I think friction sway controls suck. They're worthless in the rain, and a big PITA when turning more than the few degrees that involve sway because they bind and fight the tow vehicle trying to turn the trailer. So do hydraulic versions of them, which at least still fight sway when wet. BTW, that opinion also goes for an Equal-I-Zer hitch which just combines dual friction sway controls with the spring bars.
If you can't afford a Hensley or a Pullrite, at least get a dual-cam. That's just my opinion.
I keep hearing that friction sway controls don't work in the rain. I disagree ... I can't tell any difference, rain or shine. It is just like disk brakes, the high pressure wipes them clean of water and they work just as well.
If they are properly installed, they don't have to be fiddled with when backing. I put my Reese on when I hitch up and tighten it. I don't touch it again till I unhitch.
John W. Irwin
In my experience, the Reese friction sway control required near constant adjustment. Tightened for high winds, loosened for rain, and removed when backing to park in tight quarters. The one thing that I did observe was that this was when it was used with a trailer that was inherently unstable - - a 1980 Nomad 18 foot single axle with a wet weight of nearly 4,000 pounds - - that was teamed with a 1965 Dodge Coronet as tow vehicle (trailer outweighed tow vehcile by several hundred pounds). I initially didn't believe the caution to remove when backing in tight quarters, but learned my lesson when my first sway control was bent while parking the trailer in my side driveway.
I just purchased a new Reese friction sway control for my 6.0 Metre Minuet, and see that the owner's manual hasn't changed in its recommendations for operation significantly. If this trailer were heavy enough for a Reese Dual Cam setup, it would have one. There seems to be some confusion on suitable applications for the Dual Cam setup as the Reese represntative with whom I spoke before purchasing my first Friction Sway control indicated that the Dual Cam setup wouldn't be effective for trailers under 4,000 pounds wet weight, but I have encountered dealers who are installing it on any trailer at customer request. The Reese web site, at least on the pages I checked, doesn't mention anything regarding suitable application parameters for their Dual Cam setup.
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
Reese representative (aka, salesman), not engineer. By the weight chart, I'm under 4000lbs. dry with a '62 Overlander. Change to something else? Heck no!! Add a link to the sturip, it's not rocket science, just common sense of weight distribution. Run wet, drop a link, thats what they're there for. Oscar
I too agree with RoadKingMoe. I had the friction type on mine and removed it before my first outing and installed the Dual Cam bought directly from Reese.
The install is easy. I did drill out the rivet holding the gas line as stated above. On my 25' I had to drop the U bolts over the frame underneath the propane tank cover. Took some shuffling to get it in.
The main problem was the exact placement because it at first looks like it needs to be closer to the front of the hitch until you put the chains on. Then I found that with the arm pivoting up, the setup had to be farther back. Had to play with it for a while to get it set right! (Now an Experienced Person would have known this - this is my first time!).....
Reese says that lubing the cams will reduce the anti-sway action.
When the semi is passing, the air he is pushing is moving the back of your trailor away (or right). This pivots the trailor on the axle and the cam if lubricated would more easily slide out of the slot and defeat the anti-sway action.
Reese says if the metal on metal noise is too much, a small amount of Vasaline will quiet the noise with less lubricating effect. (Haven't tried that.)
