Old 05-08-2016, 08:12 PM   #1
1972 31' Sovereign
South San Francisco , California
Rear Frame smashes body
When I pull out of my driveway my rear frame scrapes and smashes. Y 1972 31' Sovereign. I read through the frame repair and torsion bar and height adjust sections of the site. I found info on repair work and I found info on suggestions but I can't find the the solution to this problem. I am convinced I overlooked the answer. Can someone show me where this answer is . Basically I'd like my frame to not smash my body work. I see one person with just a frame but and they don't have the bodywork on. My trailer is a working running trailer. Please I've really put some time in to solving this and I don't know solution and I can't find the answer here .
Mike Ofiesh is offline   Reply With Quote
Old 05-08-2016, 08:58 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Raise the trailer or lower the driveway.
MICHAEL
Old 05-08-2016, 09:16 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Use blocks/boards/plywood to reduce the driveway to street transition so the rear does not scrape. Slightly larger tires can help. Verify that the axle is not sagging and needs to be replaced.
Good luck. Pat
Old 05-08-2016, 09:59 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I raised my 72 three inches, I hardly ever drag anymore.
Superat stultitia.
Old 05-08-2016, 10:00 PM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Would these work?
http://www.etrailer.com/Skid-Wheels/...FQJsfgodG3wCYA
Mike
Caffeinated is offline   Reply With Quote
Old 05-08-2016, 10:21 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The word around the campfire is that drag wheels just make things worse.
Superat stultitia.
Old 05-09-2016, 01:45 AM   #7
1972 31' Sovereign
J.Morgan how did you raise your trailer?
Old 05-09-2016, 01:51 AM   #8
1972 31' Sovereign
It happens in any driveway or parking lot. I was speaking generally. my trailer needs raised a couple inches at least. Can you tell me how to raise the trailer. This trailer specifically . Can you show me where the info is. That would be the solution. Please
Old 05-09-2016, 02:07 AM   #9
2011 27 FB International
Vancouver , British Columbia
http://dexteraxle.com/torflex_lift_kit
Get the serial # off the axel[s] then contact them to verify which kit for your airstream.
[assuming the axle is dexter, I've no idea on older airstreams]
mixedpuppy is offline   Reply With Quote
Old 05-09-2016, 08:14 AM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I used a piece of 3" angle welded to the bottom of the frame, but the kits mentioned above are bolt in.
Raising my trailer is one of the best mods I made to the trailer, I highly recommend a 3" lift.
I still drag on rare occasion, but even this rare drag is reduced in severity by a lot.
Superat stultitia.
Old 05-09-2016, 11:24 AM   #11
1967 26' Overlander
Spartanburg , South Carolina
Older Airstreams like my '67 came with Henschen torsion axles. Dexter parts may fit right on them like the brake assemblies I put on mine some years ago. The original axles had a 3/4" wooden shim on each one, apparently to raise the trailer that much when new.
Even with the shims we had rear end drag and had to make it a practice to always cross driveways and intersections at an angle to prevent it. When we installed new Dexter axles a few months ago the problem mostly went away. It appears the 49 year old axles were sagging just enough to aggravate but I continue to approach intersections with caution and some I simply do not enter if I can't cross at an angle.
Jacob D is offline   Reply With Quote
Old 05-09-2016, 01:36 PM   #12
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
The axles have rubber torsion bands in them. Rubber is an organic compound that oxidises over time and no longer performs as intended. Just like tires, axles have a life expectancy. It as about 25 years under ideal conditions. As they age they begin ti sag and the elasticity hardens until the rubber is more like a hockey puck rather than a rubber band. Eventually the only suspension you have is provided by the air in the tires since the rubber axle has become solid rather than elastic. If you can be certain that there is no problem with the axle, the get a paving company to fix the ramp into your driveway.
Gearheart is offline   Reply With Quote
Old 05-09-2016, 02:27 PM   #13
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
Most likely, as has been stated, you need new axles. If things are as I assume, new axles would raise it at least 3 inches. You can specify a greater "down angle" when ordering, which will raise it even more. Even if you did not have a dragging issue, there are other very important reasons to make sure your axles are good. Mainly a rough ride and bottoming out for your trailer to endure, which usually results in popped rivets. (more than normal)
There are dealers out your way which can help you with this. First go to Inland Rv's website and read up on how to determine if you have that problem.
http://inlandrv.com/articles/dura-to...xle-92001.html
Another very helpful source, but not west coast;
https://sites.google.com/a/colinhyde...ions.com/home/
There is also a dealer in Salt Lake that carries axles. Where you buy would depend on price/shipping etc. If they have never been replaced, they are probably toast. If they have been replaced before, then it's a matter of measuring etc. to determine their condition. If you can, post a good side photo of the trailer that shows wheels and wheel well. That will help with diagnosis too. Wishing you well.
fwjumper is offline   Reply With Quote
Old 05-09-2016, 05:58 PM   #14
2003 31' Classic
Terra Alta , West Virginia
Is the trailer level when hooked? If a little high in front will make a huge difference in rear. A thought.
wvstreamer is offline   Reply With Quote
connecting a awning frame to the trailer body Stan Drury Awnings 0 02-02-2013 12:28 AM
Techniques for lifting body off frame. troyreeb Repairing/Replacing Floor &/or Frame 16 02-24-2009 09:23 PM
Jacked in the wrong spot and need body/frame advice ldetsf Repairing/Replacing Floor &/or Frame 71 11-19-2006 11:02 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 02:25 PM
