Old 05-09-2016, 06:52 PM   #15
1973 31' Sovereign
Middletown , California
The easiest way to raise it would be a lift kit between the axle and frame. If I were to get new axles I would also get the ones with more down angle. The long Airstreams all are "Drag Queens"!
ijustlee is offline   Reply With Quote
Old 05-12-2016, 09:45 AM   #16
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Try setting your WD bars after you have left your driveway. This should result in the front of your trailer dropping a little and raising your rear just a little. Maybe that will be enough.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-12-2016, 11:09 AM   #17
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
A '72 Sovereign will have Henschen Dura-Torque axles, and presuming that they've not been replaced in the past ten years, they're shot and probably have been for twenty years. That causes a lot more issues than just frame drag and can lead to body/frame separation, interior separation issues, and rivets popping. You should be able to see tread in the wheel-well looking at the trailer straight-on from the side. If you can only see an inch of sidewall above the wheel, your axles are in fact shot.
You have a number of choices for new axles and several ways to mount them; all of which will require the services of a competent welder. Were I going to do it, I'd replace the current mounts with weld-ons that you can bolt the axles too such as Dexter offers. You have a choice of "down" angles that will all raise your trailer, as well as varying the height of the weld-on mount.
Do your homework here and elsewhere online on the various axle brands, and then work with the manufacturer or a local supplier to get the right axle and axle mount for your specific situation.
Good luck!
connecting a awning frame to the trailer body Stan Drury Awnings 0 02-02-2013 12:28 AM
Techniques for lifting body off frame. troyreeb Repairing/Replacing Floor &/or Frame 16 02-24-2009 09:23 PM
Jacked in the wrong spot and need body/frame advice ldetsf Repairing/Replacing Floor &/or Frame 71 11-19-2006 11:02 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 02:25 PM
