Old 11-10-2014, 09:49 AM   #29
Goal15's Avatar
Dallas , Texas
Well you had to know that you couldn't put that disclaimer up there without somebody weighing in....
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 11-10-2014, 10:02 AM   #30
2010 22' Sport
Boise , Idaho
Santa Fe is really high altitude and it can get very cold there. Stick with Tucson!
baldwin6601 is offline   Reply With Quote
Old 11-10-2014, 10:06 AM   #31
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yep. The difference in temperature from Albuquerque to Santa Fe is pretty extreme.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-10-2014, 11:07 AM   #32
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
IH-10 from East Coast to San Antonio is generally "wnter-safe". But be aware that the weather this week will have every truck driver cutting south to that road to make east-west headway. And plenty of other fools.
This time a year ago I ran a bulk tanker load of hematite from Houston to Moab, UT. On the way back was caught with a few thousand "truck drivers" (steering wheel holders, as the insult goes) barely ahead of "Winter Storm Boreas" who tied up traffic west of El Paso with a number of wrecks of their own making. Spent the night at Van Horn and crept across 100-miles of ice to Ft Stockton for an 0700 arrival. Whereupon IH-10 was shut down from that point all the way back to Las Cruces, NM.
FWIW I'd not ever travel without full propane & full fresh water in the TT. Make adjustments to local conditions for the night. Top off fuel and water next day (come up with a way to have a substantial amount of water).
Power was out for several hundred miles in the above . . don't assume that help is just down the road. Have everything you need to keep your options open.
By the way, for those who disdain CB's: This is one of those times they pay for themselves. GPS with NAV-TEQ is handy, but nothing trumps what the man who just drove past your problem in the opposite lane has to report.
A basic CB would be:
1] Uniden 880 radio (or COBRA 29, but UNIDEN has slightly better receive; most of this is to antenna type and tuning. A 29 vcan be made to "talk loud". Either can have power bumped up)
2] Roadking RK-56 microphone (or ASTATIC 636 and maybe RANGER SRA-198; I use all three depending on radio)
3] Cobra S300 speaker (or S500)
4] Wilson 1000 or 5000 mag mount antenna (permanent mount antennas are MORE than worthwhile)
5] Power to/from battery with 20A fuse protection for vehicle at battery and fused HOT at radio. (Any other way tends to pick up vehicle electrical noise).
-- less than this is hardly worth it, IMO (or, why most folks tend to dismiss CB as being no good: Never used a decent one). You only need do it once, remember. It is cell service that is wallet-busting.
Peak & tune + pro installation should be around $200 past cost of components, parts & supplies. There are maybe 3-4 CB shops in U.S. I'd trust to do it.
GIJOES and WALCOTT 80 are said to be good online retailers. Peak & tune is worthwhile. I use CLAYS CB SHOP in San Antonio across from the Petro Truck Stop (and have used them for eighteen years; IH-10 X582 Ackermann Rd). There is no installation they haven't seen. A permanent CB set-up is gold. And the antenna can be stored when not in use. Antenna tuning isn't difficult but makes a huge difference. A shop such as the above uses the old-fashioned BIRD meter to really nail it down.
Anyone is welcome to PM me on this.
As with all days of "weather" program your GPS to show mile marker number. (Or, why a separate GPS unit can be a better buy than relying on phone map). You need to know where you are to determine where the reported problems are. An earphone is also nice with passengers.
Weather radio is also good for obvious reasons.
Old 11-10-2014, 12:10 PM   #33
asheville , North Carolina
Gonna keep an eye on that arctic front that is moving in. I'm not planning on leaving until November 19, and it will take a few days to move west from NC to the mountain west, but I've still got adequate time to modify my plans or even bail altogether if worse comes to worse.
As to Sante Fe and Albuquerque, my plans now are to park the AS in and around Tucson and just drive the tow vehicle from Tucson to Colorado Springs. Again, depending on weather.
troutjock is offline   Reply With Quote
Old 11-10-2014, 12:13 PM   #34
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
We leave Fairbanks in late Feb to head south for a couple months. When we leave here it is usually around -20 F. This is how we do it. This assumes you have forced air heated tanks.
1- We leave town with the AS winterized and the furnace running since we carry supplies we don't want to freeze and find it is easier to get the trailer warm at the end of the day when the furnace has been on. Yes we burn a fair amount of propane but if it is cold that what it takes.
2-We carry water for drinking and dishes in containers in the trailer.
3-The black tank and gray tanks each have a couple gallons of RV antifreeze in them when we leave. We use the sinks and toilet on the road and flush with RV antifreeze. We add a little antifreeze to the sink traps before heading out in the morning in case the heat goes off.
4-The fresh water tank doesn't get filled until we get far enough south that daytime temperatures are above freezing. We have camped with overnight lows down to -5F after we have added fresh water and not had any problems.
5-We don't use the city water connection when there is any chance of freezing temps as the hose and connection will freeze up. You are much better off using the fresh water tank on board.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 11-10-2014, 03:15 PM   #35
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I will have both of my Airstreams in Las Cruces for this period of time, I wont be winterizing either one. We will set the thermostat at 50 and that is all.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-10-2014, 03:51 PM   #36
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks crisen for your experience from Fairbanks. That adds a lot of credibility to towing and camping in darn cold temps. Way colder than Minnesota. I wasn't sure we could run the furnace while towing. I know many folks turn them off at gas stations, but I guess I have never turned off my fridge while fueling. Lucky so far I guess.
Now troutjock has the real skinny from an Airstreamer in Alaska.
David
Old 11-10-2014, 05:36 PM   #37
m.hony's Avatar
2013 30' Classic
I just winterized the trailer for the first time this year. I might go camping 1or2more times and do it again. I just got a gallon and a half of peace of mind.
I drained and bypassed the water heater.
I used compressed air first.
Kitchen sink hot
Kitchen sink cold
Shower hot
Shower cold
Toilet
Bathroom sink hot
Bathroom sink cold
Low point drain hot
Low point drain cold
Black tank flush
Then I used pink antifreeze in the same order.
I feel protected.
TAC #MS-10
Airforums #70955
Old 11-10-2014, 05:38 PM   #38
m.hony's Avatar
2013 30' Classic
Oh yeah-
And I drained (it's still draining) the fresh water tanks.
I drained the black and gray tanks.
Woohoo!
TAC #MS-10
Airforums #70955
Old 11-10-2014, 05:40 PM   #39
M.hony, you sure know how to party.
Great checklist, though, gonna print it out and tape it somewhere in the AS.
Old 11-13-2014, 11:04 AM   #40
Patricia720's Avatar
2003 25' Safari
Prescott Valley , Arizona
Here's a toilet solution. After I winterize, I put a thick throw rug in the shower and put a portable chemical toilet there. I purchased one that, considering the height of the shower, allows me to use the chemical toilet without needing a derrick to get up. Of course you have to empty the chemical toilet regularly but it's great to have a close option in the middle of a winter's night. I dump my toilet at the regular campground dump or, if none is available, straight into a campground toilet. I use Clorox wipes to clean the toilet after I dump.
Patricia720 is offline   Reply With Quote
really confused Julestream Member Introductions 32 11-18-2007 08:35 AM
Really, really new!! Globeville Member Introductions 6 08-20-2007 03:33 PM
Now I am really confused Theo Plumbing - Systems & Fixtures 5 01-25-2004 03:19 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
Really really great site and Airstream FrankR On The Road... 5 07-14-2002 02:10 PM
