Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 04-24-2003, 05:24 PM   #1
tiniree
tiniree's Avatar
Profile:
Question Reading the serial number question
Ok here goes (hopefully brief) -
Found out how to read a serial number (ie: length, assembly plant, floor plan, etc..). Question is on the Model. According to the serial number identification page we found, I = International, E = Excella, and L = Land Yacht.
The trailer we are looking at has the Land Yacht "plaque" on the side, but also has the "I" in the serial number (this trailer is a 1978). I would have thought that in the serial number it would have both letters, ie: IL for International Land Yacht.
Did Airstream make a Land Yacht/International combo??? Or is it possible that the seller had the Land Yacht "plaque" put on there?
I'm a little confused as to the Land Yacht insignia. Was Land Yacht a model or a classification?
tiniree is offline   Reply With Quote
Old 04-24-2003, 05:46 PM   #2
femuse
Profile:
Certain years, AS went a bit overboard in the naming of the trailers:
we have a 1974 AMBASSADOR INTERNATIONAL LAND YATCH
there was too a 1974 SOVEREIGN INTERNATIONAL LY
The VIN has only one letter for the model. The other part of the name are things like trim package, various optional things, like in ours: International as far as we can tell meant it has 2 water pressure regulators.
In 1978, in the AS list I have, I do not see a 1978 International, but that would not be the first time something weird was discovered about AS.
If the VIN says "I", and the plaque LY, you do have an International_Land Yatch.
correction: I see you have a Trade Wind. they list a 78 TW. We too have a TW_International_LY, and the VIN has a I.
That's what you have.
femuse is offline   Reply With Quote
Old 04-24-2003, 05:54 PM   #3
tiniree
tiniree's Avatar
Profile:
femuse -
Thanks! I found the "model list" with the year/model name/length, etc... and printed it up.
At this point, I'm gonna have a very BIG file and need ALOT of ink cartridges to print all the info I'm getting from this site (and we haven't even bought the trailer yet!)
Thanks again!
Old 06-23-2003, 02:33 PM   #4
ElliottBartlett
Profile:
About a year ago I found an explanation of the model number. It included a "decoding" expanation that was valid for some number of years and indicated when and where it was manufactured, length, bed type and location. I've been trying to find it again without success. It may have been in the VAC location or some other AS site.
Does anyone know where it was? Or hopefully IS?
Elliott B
ElliottBartlett is offline   Reply With Quote
Old 06-23-2003, 03:27 PM   #5
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
try this:
Serial Numbers
Old 06-23-2003, 05:24 PM   #6
ElliottBartlett
Profile:
Elliott B
Old 06-23-2003, 07:47 PM   #7
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings ElliottBartlett!
There are two serial number (VIN) decoding pdf files on the Airstream corporate site as follows:
Airstream Serial Number (VIN) Decoding Pre-1980
Airstream Serial Number (VIN) Decoding Post-1980
Good luck with your quest for information!
Kevin
Kevin D. Allen
AIR #827
Old 10-16-2004, 10:11 PM   #8
leefields
I love Airstreams...
Commercial Vendor
leefields's Avatar
Profile:  1989 29' Land Yacht
Haines City , Florida
I31 T 9 J 236 does this mean 79 or 89?
trying to id this coach i saw today
Originally Posted by chuck
try this:
Serial Numbers
leefields is offline   Reply With Quote
Old 10-17-2004, 06:24 AM   #9
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
That is a 31' International Trim, twin beds, 1969 built in Jackson Center. There also should be a plate on the lower left front side with the same serial number and a build date and GVW information. FWIW the 1980 and later serial numbers look more like an automotive VIN number. The dates are coded using letters of the alphabet, so you have to have the conversion table.
Aaron
Gotta watch those typo's
WBCCI #2449 AIR #2495
Old 10-17-2004, 08:03 AM   #10
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
If you look at the sheet you have been link to you will notice it refers to only having 3 digits at the end being in the 60's so therefore it would be a 1969
I have cliped a picture of this section
JP
JPAIRSTREAM is offline   Reply With Quote
Old 10-17-2004, 01:10 PM   #11
aztlanco
aztlanco's Avatar
Profile:  El Paso , Texas
I thought that "Land yatch" stood for "Coach" or "Rv" and that's all.
I also have a 1963 Safari (Land Yatch). The "Land Yatch" name seems to me always appears on a separate name plate on older models and not along the name emblem.
Am I correct? or have my observations been wrong?
Ernie
"58 Traveler 18ft.
aztlanco is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 11:38 PM
Serial Number Plaque 61Bambi Clearcoat, Exterior Paint & Trim 1 02-13-2004 09:16 PM
Serial number plates till Title, VIN & Registration 3 01-19-2004 08:42 PM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 09:25 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 09:18 AM
