Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 10-15-2016, 05:19 PM   #1
2017 28' Flying Cloud
Stow , Massachusetts
Ram 1500 + 28' flying cloud
Hello,
Is anyone towing a 28" Airstream with a Ram (2014) 1500 Longhorn w/ 5.7 Hemi?
Full tow package and trailer brake set up. 3.21 axle ratio.....
comeonletsgo is offline   Reply With Quote
Old 10-15-2016, 05:41 PM   #2
dasams's Avatar
Palm Desert , California
Originally Posted by comeonletsgo View Post
Hello,
Is anyone towing a 28" Airstream with a Ram 1500 Longhorn w/ 5.7 Hemi?
28 inches? Doubt that would be a problem. In fact, I suspect that it'd also be fine with a 28 footer What's the issue?
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 10-15-2016, 05:58 PM   #3
Ah Yes 28' .... eyeglasses help! And I'm a carpenter... I hear a lot of mixed opinions on this trucks capability in pulling a 28' Flying cloud. It seems fine to me, but we take delivery on our new FC next month. I'm curious if anyone else is in the same pairing of truck VS trailer.....
Old 10-15-2016, 06:07 PM   #4
FCStreamer's Avatar
2014 30' Flying Cloud
The truck should be fine. Towing capacity should be enough. It's the payload you have to watch,
What is the payload of your truck?
You should figure the trailer will put 900-1000 lbs of weight onto your payload when fully loaded. If you have a payload of, say, 1400 lbs, that leaves 400 lbs for you, your significant other, and some kick knacks.
If that's all you're bringing, you're fine.
If you were planning on bringing your Harley Davidson motorcycle in the bed of your truck, well, then you'll probably be exceeding the payload capacity. Not a good thing.
So the answer is.... it depends.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-15-2016, 06:11 PM   #5
The payload is 1080 lbs.
Old 10-15-2016, 06:16 PM   #6
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
For comparisons sake, we tow a 25' FC with a Chevy 1500 that has a payload rating of 1680. The payload rating on your truck sounds pretty minimal.
SeaLevel is offline   Reply With Quote
Old 10-15-2016, 06:23 PM   #7
2023 25' Globetrotter
Manheim , Pennsylvania
I had a Hemi like yours to pull my 25' flying cloud. It did okay but I was always maxed out on payload. I traded it in for a Ford F250 powerstroke diesel. I feel much more confident now.
Jukeboxfun is offline   Reply With Quote
Old 10-15-2016, 06:25 PM   #8
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
The hitch weight on a 28FC is per Airstream 976, but in reality more in the range of 1100. Don't have my scale numbers handy but it's heavy. One of, if not the heaviest of all Airstreams. Payload will be your issue. Put it on a scale and double check all of your weights. I pulled mine for a year or so with an F150 and just went to a 2017 F250 diesel. Love the way it pulls it. Good luck and enjoy your new Airstream and travels.
Chuck
silverlabs is offline   Reply With Quote
Old 10-15-2016, 06:58 PM   #9
FCStreamer's Avatar
That payload is very small. You will very likely exceed your payload rating. Some folks are ok with that, but I'd say you don't have enough truck for that Airstream.
Old 10-15-2016, 07:18 PM   #10
2021 16' Bambi
2021 22' Bambi
North Port , Florida
IMO with that gearing it will feel like a dog when accelerating. My Sierra has 3.73 and is OK, but like the 4.11 rear better in my brothers 2500. Also remember when you have a WD hitch the full tongue weight does not just go on the tow vehicle. For instance my 30' Bunk has about 1200 lb tongue weight but when hooked up only about 600 lbs is sitting on the truck.
cliffcharb is offline   Reply With Quote
Old 10-15-2016, 07:52 PM   #11
1991 25' Excella
Stanfield , Oregon
It should do fine the payload rating on our trucks includes 300 lbs of passengers and full fluids. If your going to be pulling big grades a gear swap would help but the hemi has lots of pulling power.
SpletKay06 is offline   Reply With Quote
Old 10-15-2016, 08:00 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have towed our FC 25 all over the country many times with a 2012 Ram 1500 reg cab Hemi, ProPride hitch. It performed so well, we got a new Ram EcoDiesel, it is terrific. If it has a tow package it most probably has a 3.55 or 3.92 axle, check it out. The 3.21 is an optional ratio for economy, not towing power.
The FC 28 has a little higher axle rating and empty hitch weight than a FC 25. I doubt the truck would know the difference when towing. Load the truck bed lightly, especially behind the rear axle. You have a (GVAR) axle rating of 3900 lbs each, front and rear, check the door tag. That's 7800 lbs before the truck axles are overladed, if you use a good weight distribution hitch and load management to load the axles evenly. Our axles load within 20 lbs of each other by the CAT scale.
Payload is the weight you carry in the truck including any trailer hitch weight at any given time. I haven't seen any reason outside of a shopping tool for manufacturers to assign a number to it. It varies from the time it hits the dealer's lot, perhaps that is why the number is precede by the phrase "should not exceed" on the door jamb sticker.
When shopping for the truck's capacity, realize that hitch weight of the trailer is not what will be added the the truck's weight after a quality weight distribution is set up. Our hitch weight is 835 lbs empty and our ProPride hitch and stinger weighs about 180 lbs. At the CAT scale after weight distribution is applied this combination of weights adds 820 lbs to our truck, the remainder to the trailer axles. That gives us almost 1,000 lbs for us and our camping equipment before we have overloaded the truck's axles or the truck and trailer combined weight (GCWR).
Some important things to know. Half-ton trucks must consider truck loads when an Airstream is attached. You will need to use the transmission and reduced speed for climbing and descending steep grades. Engine compression braking and truck and trailer service brakes will be needed to hold speed down on the steepest grades, practice and descend slowly and you will learn. These are a small part of the overall owing experience.
Many trips about the country in all terrain, weather and traffic have proven these truck's preform very well towing a mid-size Airstream for us. Absolutely stable when hitched well and plenty of power, they are comfortable, economical tow vehicles.
Doug and Cheryl
Old 10-15-2016, 08:04 PM   #13
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
If you have a tongue weight of 1200lbs before you hook to the truck, you still have it after. All you have done is distribute it evenly @600lb rear and 600lb front. It doesn't magically disappear.
George
gandttimes is offline   Reply With Quote
Old 10-15-2016, 08:15 PM   #14
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
George
malinois38 is offline   Reply With Quote
Old 10-15-2016, 08:51 PM   #15
2021 16' Bambi
2021 22' Bambi
George
That is incorrect. The weight gets distributed across the entire rig, truck and trailer.
Old 10-15-2016, 08:52 PM   #16
2017 25' Flying Cloud
Gold Country , California
George
Though some SHOULD be distributed back on the trailer axles.
I would guess if you go ahead and pull with it, you may not see the downside of overloading your payload. But I would seriously consider upgrading the truck shortly.
Enjoy your new airstream!
NorCal Matt is offline   Reply With Quote
Old 10-15-2016, 09:37 PM   #17
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Incorrect.
Old 10-16-2016, 07:42 AM   #18
2021 16' Bambi
2021 22' Bambi
Grandtimes please explain. I understand how WD systems work and have scale tickets to verify what I posted.
Old 10-16-2016, 08:20 AM   #19
silverlabs's Avatar
Waxahachie , Texas
I've not seen numbers to support 50% gets moved off of tongue as you are suggesting. Typically 20% to maybe 30% max is distributed. I've measured my 25FC with an Equalizer hitch and my 28FC with Equalizer and then when I went to a ProPride and not seen near a 50% reduction in tongue weight and scales verify that all is set up correctly. As well as wheel well measurements are correct.
Chuck
Old 10-16-2016, 09:04 AM   #20
dasams's Avatar
Incorrect.
My hitch was set-up by the dealer and the weight on my front axel dropped 200 lbs when the AS was hooked up. I adjusted the spring bars and shifted 200 to the front axel and another ~200 to the AS axels. The weight on my rear axel dropped ~400 lbs.
I don't think there is any doubt that a properly set-up WD system will shift weight off of the rear axel and on to the front axel and trailer axel.
2018 FC 27 FB
2017 FC 25 RB Gone
Going nuts worried - Dodge ram 1500 25' flying clound Jukeboxfun Tow Vehicles 71 04-25-2015 09:14 PM
Hemi-Powered Ram 1500 versus 30' Classic LittleRadio 2001 - 2005 Classic 34 10-19-2014 09:10 PM
Dodge RAM 1500 SLT 5.9 liter tow vehicle abridges01 Tow Vehicles 10 08-17-2006 08:25 AM
