Old 06-19-2014, 10:05 AM   #1
TXMYTX's Avatar
2009 27' FB International
Rio Medina , Texas
Problem with Rear Tail Light, '09 International
Ever since I bought the trailer, I've had trouble with the right rear brake/signal light unit...Sometimes it would work, often not. I've changed the electrical connections from the trailer to the TV several times ...Works for a while ... Completely out now. No problem with the left light..
TXMYTX is offline   Reply With Quote
Old 06-19-2014, 10:52 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Incandescent?
I've changed the electrical connections from the trailer to the TV several times...
Have you checked the tail light itself. If I recall correctly the 09's do not have LED lights, so the bulb(s) could be loose in the socket, or the wires to the socket might have a loose connection - solder or twist connectors? Or I suppose the bulb itself might have a damaged filament. (BTW an upgrade to LED's gets you a much brighter light and there are fewer things that go wrong with these fixtures too.)
If none of those, UGH - you might have a short in the wiring to the fixture itself. The area between the skins is just full of sharp edges, and if a wire rubbed against one of those it could cut through the insulation.
Good luck, hope it's something easy to spot.
Foiled Again is online now   Reply With Quote
Old 06-19-2014, 11:13 AM   #3
2008 25' International CCD
Ketchum , Idaho
Has an anti-sway bar been added to the curb side of frame?
I discovered that when holes were drilled to mount the sway-bar bracket the cable was hit and a short occurred. I pulled out the rubber grommets and was able to pull the cable out (under the trailer) just far enough to discover a very tiny hole. Upon stripping back the outer insulation I found two wires had been damaged - causing a short to my right side blinkers.
nwmsmith is offline   Reply With Quote
Old 06-19-2014, 07:35 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check the ground/common connection on the tail light fixture. If it is loose or corroded. It will cause a problem.
Old 06-19-2014, 08:21 PM   #5
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I can't tell what your TV is, but if you have separate turn signals and brake lights, then you have a converter to change that to the combo brake/turn on the trailer. My lights would work fine for a while, then one side would go out. It was the converter failing - I've had to replace mine twice.
robert claus is offline   Reply With Quote
Old 06-19-2014, 08:47 PM   #6
TXMYTX's Avatar
Rio Medina , Texas
Robert...what converter ?
Old 06-19-2014, 10:24 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have an '08 Tundra which has separate turn signals and brake lights.
I did not have to make any changes to pull the ARGOSY other than to match the old wiring scheme to the modern pin out. . Most trailers do not have separate brake and turn signals. If you have a modern TV it should not be a problem.
Old 06-20-2014, 06:12 AM   #8
2000 19' Bambi
Taillight converter
If you have separate brake lights and turn signals on your TV, then somewhere in-line is a converter that turns the two signals into one for the trailer tail lights to function properly. If your vehicle has the separate circuits and a factory towing package, then it is integrated somewhere. It could be the source of this problem, and is worth checking out. My Sprinter had a factory converter plugged in under the seat which failed repeatedly, giving me taillights function on just one side after operating a while. We'd check the lights before leaving-all fine- and find a problem when rechecking after stopping later. I wired in a Curt powered converter #56146 in place of the factory Mercedes unit, and had no trouble for a couple of years. I recently had to wire in a new Curt unit after the problem reappeared last fall. Once again, problem solved.
Old 06-20-2014, 11:42 AM   #9
TXMYTX's Avatar
Rio Medina , Texas
Got it...thanks....
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
Crazy tail light problem chuman70 Lights - Interior & Exterior 4 10-01-2010 08:31 PM
Weird Tail Light Problem mello mike Lights - Interior & Exterior 8 06-24-2009 09:36 PM
63 Globetrotter tail light problem 63air Lights - Interior & Exterior 3 09-21-2007 06:08 PM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
