Old 10-26-2017, 05:40 PM   #1
2017 28' Tommy Bahama
Lake Oswego , Oregon
Probably an old topic about storing
We have a 2017 Airstream Tommy Bahama. We store in a 3 sided bay open on one end. There is not enough light to get any benefit from solar. The C02 detector is wired directly to the battery creating a slow trickle. The dealer said since we store on shore power, it’s OK to store in USE MODE versus STORE MODE to maintain the battery (4 stage charging).
Some commentary on another forum said you will damage the converter doing that. Any expert opinions to share? Thanks.
Ridget is offline   Reply With Quote
Old 10-26-2017, 06:45 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
You store at home?
I put a switch on the LPG detector....off in storage.
We have two grp27 Lifeline AGM's. When the trailer is stored for over a month, I ck ones a week & when it gets under 12.5v It gets plugged in for 24hrs.
I would....leave it plugged in 'til fully charged, un-plug and ck once a week.
Repeat as needed.
My sex life is like a Ferrari...
I don't have a Ferrari. 😘
“It’s a crooked piece of time that we live in….”
John Prine
"Tahawus"
Old 10-26-2017, 06:54 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
Just disconnect the battery. Then charge battery once a month? Just wondering.
Daquenzer is offline   Reply With Quote
Old 10-26-2017, 07:28 PM   #4
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
If you have power available all the time in the trailer anyway, why not buy a trickle charger that is designed for long-term use and just leave it plugged in? Trickle chargers are not that expensive, because they don't require any heavy-duty components. They charge with small amounts of power over a long time, the same as your solar would if it were getting any sun. When I used to be into motorcycle touring, I would leave a trickle charger connected to my battery over the winter months. I knew that whenever I had the desire to take off on the motorcycle, I would leave with a full charge on my battery.
McDave is offline   Reply With Quote
Old 10-27-2017, 09:14 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Would a portable solar panel in the open end of the shed help?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-27-2017, 09:33 AM   #6
Happy Camper
nipperguy's Avatar
1973 31' Sovereign
2017 27' International
Raleigh , North Carolina
Send a message via AIM to nipperguy
After installing a Progressive Dynamics PD 4655 multi-stage converter, we keep our 2017FB plugged in continuously. Prior to the 2017, we had a '73 with a PD multi-stage converter that was kept plugged in for years. Never any damage to converter and batteries lasted many years. If you have wet batteries, just remember to check them monthly and make sure they are sufficiently watered.
nipperguy is offline   Reply With Quote
Old 10-27-2017, 09:36 AM   #7
BoatnutG2
2015 28' Flying Cloud
Fountain Valley , California
Am I missing something?
What is the point of the “store” setting if the propane detector is still operational and runs the battery down? Shouldn’t the propane be turned off when the AS is in storage? Is the detector still needed?
On my boat I have a remote solinoid to shut off the propane when there is no 12v. Why not do the same on the AS: connect a remote gas solinoid and the detector to the “use” circuit and disconnect the detector from the “store” circuit?
Or is the detector there to detect something besides propane?
BoatNutG2 is offline   Reply With Quote
Old 10-27-2017, 09:38 AM   #8
2017 25' International
Framingham , Massachusetts
Assuming you have the factory installed solar, the AGM batteries and multistage converter/charger that come with that option will be fine plugged in all winter as the dealer advised.
BTW, the smoke detector and carbon monoxide detectors run off of a 9v battery inside each (NOT wired to house batteries)! Please remove these batteries and replace with fresh ones in the Spring! We don't want to lose any forum members via misinformation!!!
Only the propane leak detector is hard wired to the trailer batteries.
quietguy is offline   Reply With Quote
Old 10-27-2017, 09:40 AM   #9
Liability laws.
Old 10-27-2017, 10:01 AM   #10
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
I store in a public covered unit, batteries with installed disconnects open, on a temp compensated trickle charger. Ran the charger cord out the hole in the floor under the couch to keep the charger out of the weather. The trailer is powered from 12ga extension cord run through a locked window to a man- killer 120v jumper plugged into an outlet inside, that happens to power up the converter and several other outlets to keep the rodent and pest zappers on, and allows easy lights on when we visit and keeps the wife confident the mice won't move in.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 10-27-2017, 11:06 AM   #11
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
All one needs to do is move the power lead for the propane sniffer to the other side of the use/store solenoid. This will kill the phantom power loss, and the alarm that no one will hear when parked in storage.
"Chip Tank" is in Paso Robles Ca.
CDONA is offline   Reply With Quote
Old 10-27-2017, 11:41 AM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It might be nice to have it operational if the interior filled with gas while in storage.
I also agree with McDave. I leave mine on a small charger while in storage.
2012 Dodge Durango Hemi/AWD
Old 10-28-2017, 10:47 AM   #13
CDONA's Avatar
Yes, it is a choice.
If parked in your yard you may hear the alarm, if it goes off.
Parked at a remote storage yard, no 120 power to run battery tender, who will hear it then?
If you turn off your propane tanks at the valves, there won't be anyway to pool propane inside.
I'm just pointing out an easier way to switch the power to the sniffer, without extra parts.
Old 10-28-2017, 11:35 AM   #14
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The propane detector is not the only "parasitic load" on the trailer. There are several others lurking here and there. Disconnecting the battery is easier than pulling all of them off here and there.
One dirt cheap approach is to simply get a programmable timer. Let it bring up the shore power once a week for an hour or two. Is it cheaper than a trickle charger? Who knows. Is it better for the batteries? that depends ....
New Member probably old questions but here goes... hobrannon Member Introductions 2 07-12-2016 11:08 AM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
New Member Probably Old Question madpaddler Trailer Values 5 05-10-2010 11:01 AM
Renew old tire topic: 7.00-15 to 225/75R-15 jdnorris Tires 2 07-10-2009 02:21 PM
If you think it is bad, it is probably worse j54mark General Repair Forum 5 09-27-2003 05:54 PM
