Old 05-27-2015, 12:35 AM   #1
ShinyToo
Ggroth's Avatar
2011 25' FB International
2013 Interstate Coach
Franklin , Wisconsin
Power out TV outlets
Never had this happen. Using 30amp service at a campsite in ID. Suddenly, no power to either TV electrical outlet. Checked circuit breaker and 15 amp fuse OK. Any suggestions?
Ggroth is offline   Reply With Quote
Old 05-27-2015, 12:49 AM   #2
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
I don't know what model or year you have but on our 2012 EB the TV outlet is wired thru the bathroom GFCI, so you might check to see if it popped.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 05-27-2015, 12:50 AM   #3
Spamcan's Avatar
2015 30' FB FC Bunk
Portland , Oregon
Any chance your TV is plugged into an inverter outlet, and the inverter switched off?
Spamcan is offline   Reply With Quote
Only one out of 4 outlets is serving power kayt Electrical - Systems, Generators, Batteries & Solar 7 09-23-2013 04:12 PM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 03:15 PM
'65 Overlander no power to A/C or outlets Benvenito Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-27-2010 09:33 PM
What outlets are available when using battery power? jagzoo Batteries, Univolts, Converters & Inverters 26 06-01-2010 03:08 PM
