Old 05-28-2009, 11:18 PM   #1
1978 25' Tradewind
Walnut Creek , California
Plugged in but only partial electricity
Hello. I have 1978 Tradewind and I am leaving for a trip in the morning. Murphy's Law is in place as I am just now experiencing an electrical issue.
Please help if you can.
Despite being plugged in, all of the lights are dim, the water pump is barely turning and the control panel charging light is NOT illuminated. What is odd is that the refrigerator is working on the electrical setting and if I plug something in to one of the interior sockets, it will work as well. Neither of these (sockets or refrigerator) work when the trailer is unplugged so it means some electricity is getting through. The only thing that has happened over the last week which I can site is that we accidentally ran over the charging cord when it was snaked through the garage while charging the trailer. I tested the battery and its volts are extremely low. It is at 7 volts when it should be around 25. Could the battery be fried and be inhibiting electricity to the remainder of the trailer? Any other ideas? Thank you in advance.
Lufetarg is offline   Reply With Quote
Old 05-28-2009, 11:24 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
It sounds like the power converter (Univolt) is either unplugged, a circuit breaker is tripped (the circuit that the Univolt is on), or the power converter (Univolt) has ceased to operate. From your description, it sounds like your water pump, etc. are trying to operate on the limited voltage available from your weakened battery.
The lights and water pump are both strictly 12-vot DC. Your refrigerator and electrical outlets utilize 120-volt AC (unless your refrigerator happens to be a 3-way replacement) -- these will work when plugged into shorepower even if the power converter (Univolt) is not operational and the battery is low or not in place.
Kevin
Kevin D. Allen
AIR #827
Old 05-28-2009, 11:49 PM   #3
1978 25' Tradewind
Solved, thanks to Overlander64
Overlander64 is a stud. It was a tripped fuse. My newbee ignorance required a point in the right direction and it was the breaker panel. There was a 15amp fuse tripped. Flipped the switch and I am back up and running. I am hoping it does not repeat. I did plug a laptop into one of the sockets yesterday. Perhaps that was the issue. Regardless, I greatly appreciate Overlander64's quick input. I leave in six hours on a trip and will sleep better knowing the trailer is back online. Thanks again.
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
plugged in rashton Electrical - Systems, Generators, Batteries & Solar 3 05-24-2008 01:38 PM
Plugged in 24/7 Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 21 12-04-2006 10:55 AM
Can I leave it plugged in?? KeithCheri Electrical - Systems, Generators, Batteries & Solar 14 10-05-2006 02:10 PM
electric humming when it's not plugged in AnnZ3 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2004 06:27 AM
