I have to admit that I am the worlds biggest novice at this, and I need some help figuring out what the following numbers mean:
I am about to purchase a 25' International CCD. The Airsteream price sheet shows that this model is 6,300 Lb. GVWR and has a 6,000 Lb. axle system. At the bottom of their sheet, it says that the factory weight without options is 5,270 Lb. and the additional allowable weight is 596 Lb.
Here is where I am lost. What is the difference between the 6,300 Lb GVWR number and the 5,866 factory weight option? What is also the purpose of the 6,000 Lb. axle system weight? What is the number that I should use to figure out if my truck is capable of pulling the trailer?
I too had the exact same questions as it seemed kind of off to me too. The only real numbers you need to worry about is the GVWR, which in this case is 6,300lbs and the hitch weight of 750lbs. The fact that it's a 6000lb axle system means that the axles are rated to hold 6000lbs total (maybe 3k each). The rest will be sitting on the tow vehicle. So you need to pay attention the 6300/750 numbers and make sure your tow vehicle can take on both. Mostly though the hitch weight is only a real concern if the hitch can take the weight, but you never know, there are some folks out there using Intrepids to tow HUGE Airstreams!
Eric
6300# is the maximum amount the trailer can weigh, no ifs, ands, or buts.
6000# is what the axles can carry, no ifs, ands or buts.
Keep in mind that 10 to 15% of your gross trailer weight (6300#)will be on the hitch, and the other 85-90% will be on the axles.
Those other numbers can vary, depending on options. I would go with a vehicle that has at least a 7000-7500 pound trailering capacity for this particular trailer. Make sure it can handle up to 1000# of trailer toungue weight.
The best thing to do is scale the trailer with full water, propane, to see what it ACTUALLY weighs. Then you know how much additional "stuff" you can put in.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
Use 6300# to figure out whether your truck can pull it. It is best to have 20% to 25% excess capability in the truck to give satisfactory towing performance (mountains, etc).
The 6000# axle weight is not a real important figure at this point.
As to the arithmetic, I can only say that Airstream must have a broken calculator somewhere because over the last 2 years I have seen a number of calculations that don't add up (including my own trailer). I think that they juggle the numbers and tend to mis updating some of them.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
I agree the important issue is GVWR. To do the math, if you're interested, you can also deduct the weight of the axle, brakes, wheels and tires (and half the weight of the springs, shocks and hardware) from the GVWR to determine the axle load. So don't worry about the rating of the axle, by the time you subtract the hitch weight (600-750#) and all the unsprung axle weight (about 300#?), you are well below the allowable carrying capacity of the axle.
Thanks for all of the great information. If 6,300 is the number that I should go off of, I belive that my truck will be capable of towing this trailer.
I have a 2003 GMC 1500HD which is capable of towing 7,700 lbs.
If I add 20% to 6,300, I come up with 7,560. If I deduct, 20% from 7,700 I come up with 6,160.
You have plenty of towing capacity with that truck. My 5.3 Z71 took my trailer over Raton Pass with no problem at all. The 6.0 in the HD is tuned for a lot more torque than my 5.3.
John W. Irwin
I too have a new 25' International, and I pulled it to the NC mountains last week with a 2003 Chev 1500. The steep grades of 8% caused the truck to downshift and rev a bit, but those were steep grades. Otherwise I was able to run 65 to 70 MPH easy. BTW, which model did you buy?
Yes Josh, that was my question. I saw you had written that in your first message, but I had not read it properly.
Your truck is an HD, so you should do even better than I did.
I am 35, and this is my second travel trailer, first Airstream.
I hope to be able to use this one more than I was able to use my first one, but I can assure you that any time spent in the CCD model will be awesome.
Do you know when you are getting yours or where you will go first? Fell free to share.
FYI, We went to the Atlanta RV show last weekend just to see all of the other trailers out there, and nothing came close to making me regret the decision to move up to an Airstream. There simply is no comparison, especially with the CCD models.
I am currently in China on business and will be back towards the middle of the month. As soon as I return, I will be signing the contract. The dealer has told me that I can expect to see the unit in December or January.
Because I have been in China for so long, I will not have a lot of time to go on a trip immediately. After I pick up the unit, I will probably do a quick run to Las Vegas because I have clients there. From what I have heard, Circus Circus has a decent RV park.
I am glad to hear that you were very impressed with the CCD. I am definitely looking forward to getting it. The one thing I may do is customize it a bit. I am in the furniture business and we specifically manufacture wood veneer products.
I will of course have to wait until taking possession of the unit, but I was thinking about removing some of the panels and putting a sharp looking veneer over them. Of course, this may look totally goofy along with the CCD interior so I will just have to wait and see.
What do you think, could the CCD use some dark, rich woods in the right places?
I was born and raised in Atlanta, GA and besides one 3 week vacation covering Italy, Austria, and Amsterdam, and one to Costa Rica, I have never left the South Eastern US.
One of my goals is to travel the mid west, etc. to see more of our country.
As to wood in the CCD, unless yours is different, I can't picture it working. Everything is either black, white, or a solid flat color. Mine has blue cushions and white over-head cabinets with orange inside.
The only wood look is the floor. The main attraction for us was the fact that the trailer didn't have all of the wood and usual upholstery that you see in other trailers.
So far, the main thing I have added is colorful throws and throw pillows to play on the bright color scheme. I added some purple, orange, and yellow.
I had at least 6 people come to see the trailer while on the first trip. One couple had an Airstream, and promptley told me that I had to join a club.
You had better get used to it. These things get the attention they deserve.
