Old 06-16-2017, 06:23 PM   #1
Wellfleet , Massachusetts
Picked up new 2017 Classic no shore power?
Hope some one can help. We picked up our new 30 Classic. Stayed overnight at the dealer last night and everything worked fine. Just arrived at our first stop an the way home. Plugged in our new progressive EMS-PT50X surge protector and plugged in to shore power...the surge protector displays....but no power to our trailer .... we get the following display:
We called voice mail....any thoughts???
Joellen is offline   Reply With Quote
Old 06-16-2017, 06:31 PM   #2
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Take out the sp and do you have power?
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 06-16-2017, 06:37 PM   #3
2012 30' Classic
Homosassa , Florida
Check the breakers inside the trailer to make sure the main isn't tripped. Also, make sure you twisted the connection to the trailer before you tightened the threaded ring.
Tater is offline   Reply With Quote
Old 06-16-2017, 06:39 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
How long did you wait before panicking? They have a "pause" of up to several minutes before allowing power to flow.
You also need to make sure the use/store switch in on.
Failing everything else, unplug the surge protector, and try power without it.
Old 06-16-2017, 06:44 PM   #5
It may be working now...
So the power came on and the AC is running....but on the control panel display the DC Power is darkened....does that mean on or off?
Old 06-16-2017, 06:49 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
From the manual - If the digital display is illuminated, reading an E 0 error code, yet
you have no power in the RV, please contact Progressive Industries Tech
Support. Please remember you must wait the 2 minutes 16 seconds (136
seconds) for the time delay countdown.
I think it is telling you that you have 123 volts on both Line 1 and Line 2, and line 1 is drawing 1 amp and line 2 is drawing 2 amps. Did you wait the delay time out? Have you checked the breakers in the trailer?
Had you used the surge protector before? Have you tried it without the surge protector?
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-16-2017, 07:44 PM   #7
Llando88's Avatar
2016 30' Flying Cloud
If you are talking about the Progressive unit's 'control panel' display, if you have power in the coach but no rolling status displayed in the panel, you have a fault and need to contact Progressive.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is online now   Reply With Quote
Old 06-21-2017, 02:48 PM   #8
JFScheck's Avatar
Rockville , Maryland
Images: 33
Stupid question, but do you have all breakers at the power junction box enabled to ensure you are getting both phases of power to the Airstream?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 06-21-2017, 03:25 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
The first E-0 means that all is well with the surge suppressor. E (any other number) is something you need to dig into. The timeout freaks me out each time I hook up. There is just enough time to go find out that nothing is working, kick this and that and then get back to see all is well with the suppressor.
Power up - there's a red button on the main panel just inside the screen door. It needs to be "on" to enable 12V to all the "stuff". Turn it off and everything dies. Just above that are the internal and external masters. Punch them both to "on" just in case.
Lighting on the various panels is controlled at the panel (bed panels) or on the master by the Alde control (area above the main TV. Alde turns on independently of the other stuff. The HVAC is run on the panel under the BluRay player. It lights up when you punch a button.
Breakers for the 12V and FireFly stuff are under the right hand wardrobe door (behind the wood panel at the floor). The main AC breakers are behind the wood panel to the left, under the wardrobe. To get to them, you open the black door that is behind the wood panel.
Hopefully you have a circuit tester. Ours is plugged into the outlet by the stove. It lights up to show you that AC is present and there are no serious issues. If you didn't get one from your dealer, stop by Home Depot or Lowes and pick one up. It's a really good way to verify that you have shore power hooked up.
So much fun !!!!
picked up my 2017 FC 19C bunk yesterday Roguegaston 2005 and newer - Bambi all models 9 06-16-2016 09:48 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
