Old 08-20-2014, 11:02 PM   #1
2014 27' Flying Cloud
Seguin , Texas
Picked Her Up Today!
Home safely with our FC 27' FB Twin. Spent a few hours at the dealership doing walk thru with the service department and getting a few things in the Parts Department. We have so much to learn. Already realize that we're definitely going to need some checklists to help us with setup, take down, etc...
Are there any comprehensive checklists hidden away here on the site? We're so excited to get out on the road!
Mark
Laidback1 is offline   Reply With Quote
Old 08-20-2014, 11:29 PM   #2
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Read Richard Luhr book, "Newbies guide to Airstream", several checklists there.
Luigi123 is offline   Reply With Quote
Old 08-21-2014, 06:55 AM   #3
Seguin , Texas
Thanks!
Old 08-21-2014, 07:07 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
A good place to start is with your Owners's Manual. Mine has several basic check list. Also the already mentioned Newbies Guide is an excellent quick read with more comprehensive list. It contains many little tips to help with the basics.
MICHAEL
Old 08-21-2014, 07:51 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy, LB!
Congrats again!
The "best" checklist is yours. It is possible to take the ASOM(Airstream Owners Manual), work through your AS multiple times. If you have help who can type, ask them to take notes as you carefully process through each sequence.
Most important now would be operation of each system. In the ASOM you will find water (fresh, waste, hot/cold/filtered/12VDC pump/external source), 12VDC supply, converter, battery maintenance, external electrical, etc )
Your own current and developing knowledge of these basic items will drive the depth of detail....here is where a "checklist" becomes personalized. If a step says "check tires" or "check converter, is that enough info for you to know the process "by heart/memory"? If so, all you need are simple listed items.
Now, this may prove interesting reading after you use the AS a few months. May even bring a chuckle or two.
Enjoy the journey!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-21-2014, 08:31 AM   #6
FCloud9's Avatar
Mohnton , Pennsylvania
Second the above advice. AS Manual & Newbie Guide read& repeat and don't leave home without them. Each experience you will learn new operations- we're new too!
Congratulations on your new Airstream & enjoy the adventure!
FCloud9 is offline   Reply With Quote
Old 08-21-2014, 09:04 AM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Departure Checklist
Here is the one I developed to use; other members may add their comments as well. The first important item is for partner to locate and use the check list as it relates to their responsibilities AND use it faithfully.
Departure Checklist
Interior
Stow loose interior items
Lockers/Drawers: Closed & Secure
Galley: Check/secure
Water heater: Switch OFF
Bathroom/shower doors: Secure
Windows / rock guard: Close/latch all
Lights: switch OFF
Refrigerator: set for travel & *lock shut*
TV *2: Secured to store position
TV Antenna: retracted
TV antenna booster: OFF
Vents: Closed and motor OFF * 2
Water pump: OFF
Furnace OFF:
Dog: watered / walked / happy
Cell phones, Glasses: to Tow Vehicle
AS keys: to Tow Vehicle
Exterior
Awning (if deployed): Furl and stow
Tire pressures: Visual / gauge check
Stabilizers/Leveling jacks: Retract
Leveling blocks: stow
Power cable: Disconnect/stow
Generator: as appropriate / stow
Range Vent: locked - if used
Water supply: Disconnect/stow
Sewer system: Disconnect/stow
Propane: Set for travel
Hitch: connect TV/AS
Hitch: Check hitch safety pin
Bars, EQ: Pinned & safety catches inserted
Safety chains: crossed & attached
Chocks Remove/stow
Umbilical: Inserted and & attached
Walk around inspection
Entry steps: retracted
Lights/signals/brake: check
Main door: Secure/Lock
Check site for forgotten items.
On her way to her new home😃 Denda Airstream Lifestyle 1 04-10-2014 05:54 PM
saw her on her way home? moparjohn On The Road... 1 12-22-2013 04:49 PM
Got her name on the back of her belt... Stella Airstream Lifestyle 6 07-20-2011 12:10 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 06:41 AM
Picked up the 59 today!!!! 59toaster Our Community 9 02-16-2003 04:16 PM
