Old 08-27-2005, 09:21 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Parking Levels
Are these a good thing to have?How many does everyone who uses these use.Where do you all place these on the trailer.Thanks
here is a site for it.
http://www.campingworld.com/browse/s...m=6440&src=TSC
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 08-27-2005, 09:54 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Devoman,
If the level is good you only need one of that type and it typically is mounted front and center under the window. I have heard of some issues with that brand of level recently...poor quality, liquid leaking out, etc. I have one and it is pretty decent except when I smack it changing LP tanks, then I have to re level it. I usually carry a small magnetic torpedo level and just plop it on one of the frame rails for a second opinon.
Aaron
WBCCI #XXXX AIR #2495
Old 08-27-2005, 10:07 PM   #3
I just use about a 12" carpenters level. When I pull into a spot, I toss it onto the propane tank cover and check the level side-to-side. If necessary, I'll pull one wheel onto a board or two. Then, after I'm done unhitching, I toss it onto the floor of the trailer (while my wife is unpacking the inside) and she'll yell when we're level front-to-back.
Claybuster is offline   Reply With Quote
Old 08-27-2005, 10:19 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
devo
in my opinion the tamarak level is the way to go for a airstream. i just replaced my original one after 13 years of service. the tube finally cracked letting the liquid out.
you only need one mounted on the front of your trailer, each hash mark equals 2 inches of blocking needed to level the trailer.
the replacement i purchased is of similar quality of the original. good.
john
you call them ferrets, i call them weasels.
Old 08-27-2005, 10:36 PM   #5
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I have saw those on some other T/Ts , I think they are rather large,and it stands out like a sore thumb,I like the smaller ones,
scf31 is offline   Reply With Quote
Old 08-27-2005, 10:49 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by wahoonc
Devoman,
Aaron
FYI, centering under the front window really isn't necessary. My dealer mounts them under the front window but at the street side corner of that window. That keeps it clear of the tanks. Level there is just as level if it is centered, and it does allow you to see the bubble from your driver's side door mirror when you park. Here's a picture of this type of mount.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-28-2005, 02:24 AM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
ahh yes jack, yet another advantage of having a wide body trailer!
john
Courtesy Parking markjoandall Our Community 11 03-16-2012 09:59 AM
Parking it up north: advice? tonigm Our Community 1 10-17-2002 09:06 AM
Airstreams in Museums melprice Our Community 13 07-17-2002 01:14 PM
WBCCI courtesy parking John On The Road... 2 04-12-2002 03:23 PM
