Old 10-07-2014, 06:59 AM   #15
gomotomoto's Avatar
Longport , New Jersey
Overdrive. Should I use it?
Originally Posted by top View Post
awesome!!! Which airstream is that?
gomotomoto is offline   Reply With Quote
Old 10-07-2014, 07:03 AM   #16
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I've skimmed through the thread and am going to give my answer which may already agree with some of what was posted above:
1. Read your owner's manual and follow any advice it gives. (Often, though, these tell you what the switch does without telling you when or why to use it.)
2. Failing that, the safest thing to do is turn the overdrive off (i.e., hit the button or switch). This locks out the overdrive gear and may also affect how it shifts, when it shifts, etc.
3. If you're on level land, just rolling along, it's probably safe to re-engage overdrive and get slightly better fuel mileage. I never did with my motorhome though.
4. Here's the real key: If the transmission is hunting between gears, turn off overdrive. If it's hunting between 3rd and 2nd, downshift manually to second. For my motorhome, I always towed with overdrive off; and once or twice I found myself downshifting into second.
Just in case it's not clear - "hunting" in this case means it downshifts, then a moment later upshifts again because of the speed, then the engine can't generate enough power, so it downshifts again and the cycle repeats. This is really hard on the transmission. Don't let it do it.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-07-2014, 07:19 AM   #17
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Abby is a 1972 29' Ambassador.
Lance
Top is offline   Reply With Quote
Old 10-07-2014, 07:20 AM   #18
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Owner's manual
Good advice.
The Sequoia owner's manual specifically states to turn OD OFF while towing.
Lance
Old 10-08-2014, 04:08 PM   #19
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
Hey any one knows about a Jeep grand wagoneer? I don't have an owner Mabel?
Sent from my iPhone using Airstream Forum
Twinke58 is offline   Reply With Quote
Old 10-08-2014, 04:47 PM   #20
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
The 84-91's have a three speed automatic with lockup torque converter. Tow in "d".
The 1993 Grand Waggy ZJ has a four-speed transmission. In general, as stated above, defeating od will allow the drivetrain to deliver "direct" drive 1.1 rotation to the axle, thus reducing the tendency to lug the engine or force downshifts. Try to keep the converter locked, thus reducing slippage, thus heat transmitted to the fluid, which has to be mitigated by the cooling package.
14 Serenity 28'
15 Grand Cherokee EcoD
#5261
westernjeep401 is offline   Reply With Quote
Old 10-08-2014, 04:58 PM   #21
Twinke58's Avatar
1958 26' Overlander
Sorry Manuel.
Old 10-08-2014, 04:59 PM   #22
Twinke58's Avatar
1958 26' Overlander
Thanks! And yes I have that.
Why shouldn't I use overdrive? mddsmith Tow Vehicles 37 01-10-2010 10:35 AM
"Overdrive" for 370 noiva Mechanics Corner - Engines, Transmission & More... 20 12-10-2005 06:39 PM
GEAR VENDORS overdrive, same as units IPM Mechanics Corner - Engines, Transmission & More... 12 07-02-2004 10:13 PM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 09:19 AM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 11:36 AM
