Old 08-15-2019, 11:14 AM   #1
2017 16' Sport
Canyon Country , California
Our Wish List for Airstream Jefferson Center
What is your wish for your Airstream camper? 45 footer? Slideout? etc. etc.
My wish for Airstream Jefferson Center to put in a power cord retractor inside.
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 08-15-2019, 12:37 PM   #2
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I wish I could add a reel for the 50 amp cable. Anaconda actually!
Also, that would be Jefferson Starship Center!
Or actually, Jackson Center, ohio.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is online now   Reply With Quote
Old 08-15-2019, 01:48 PM   #3
2017 16' Sport
couldn't think right at that moment
2017 M16 Bambi
Old 08-15-2019, 02:21 PM   #4
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
You know they do make a power-retractable reel that would fit into an Airstream side or rear compartment. I ran into a gentleman at Alumapolosa and he had it in his catalog. I believe it was $179. Might be good for a 30 amp cable. but probably not for the 50 amp
Old 08-15-2019, 02:51 PM   #5
2017 16' Sport
ahhhh there is no room for the retractor in the Bambi 16 footer, but not upright. maybe wheel hangin horizonally under the floor rather than vertical anywhere inside. of course with cover similar to spare tire cover to protect the retractor from dirt and flying rocks.
2017 M16 Bambi
Old 08-16-2019, 09:06 AM   #6
1969 18' Caravel
Greenville , whereEverIroam
A modest list
My wishes for AS are, I believe, rather modest:
1) Implement lean controls to increase the quality of the fit and finish of your trailers. Do you really want customers discovering incomplete or improper assembly, cables misrouted, loose screws, construction debris strewn about, poor caulking, etc.? Let's clean up the trailers and do it right, do it once, the first time.
2) Let's improve the product itself -- let's engineer the trailer to work in the environment for which it is intended. No more placing ammonia evaporation refrigerators in the BaseCamp in direct sunlight without adequate ventilation such that they don't work. We really should not have to point this out. No more designing trailers with suicide doors, or doors that impinge on open windows or awning arms. Let's make sure when we introduce new products like (nest) that they are not an embarrassment to the brand. Test products to failure, then fix the problems discovered. Design-Build-Test. Let's design intelligently, not lazily, or not doing it at all. Think.
3) How about putting in a sub-floor that will not rot? Other trailers have aluminum flooring. There is also a remarkable composite material called Coosa Board that is just as strong and easy to work with as plywood, but is water proof, critter proof, mold resistant, and 30% lighter than plywood! WOW! The added cost of the material is a fraction of the total cost of the trailer but would last for decades, if not longer.
4) Change the mindset of Thor from milking the Airstream brand for as much profit as possible, and focus instead on making the best TT on the market (while still making a handsome profit) and reap the rewards. In other words, be more like Apple in this regard.
If Airstream does this, it would set the standard in the domestic RV industry, become the quality leader in the market, burnish it's brand reputation, be more responsive to customer needs, innovate next generation technologies that are both useful and effective and set the company on the path to even greater success.
skyguyscott is offline   Reply With Quote
Old 08-16-2019, 10:02 AM   #7
2017 25' International
Framingham , Massachusetts
Ain’t this the truth?!?!
quietguy is offline   Reply With Quote
Old 08-16-2019, 10:22 AM   #8
palm beach gardens , Florida
three cheers for Skyguyscott!!!
m rafferty is offline   Reply With Quote
Old 08-16-2019, 10:54 AM   #9
journeydog's Avatar
2018 28' Tommy Bahama
Silver City , New Mexico
MAKE NO CHANGES - ONLY IMPROVEMENTS
-Wally Byum-
Class A Safari Trek 2830 - SOLD, TC Lance 1010 - SOLD,
TT Arctic Fox 30U - SOLD, TT Forest River Mini - SOLD
Class B+ Pleasure Way P
ursuit - FS, $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 08-16-2019, 11:43 AM   #10
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
my wishes for as are, i believe, rather modest:
1) implement lean controls to increase the quality of the fit and finish of your trailers. Do you really want customers discovering incomplete or improper assembly, cables misrouted, loose screws, construction debris strewn about, poor caulking, etc.? Let's clean up the trailers and do it right, do it once, the first time.
2) let's improve the product itself -- let's engineer the trailer to work in the environment for which it is intended. No more placing ammonia evaporation refrigerators in the basecamp in direct sunlight without adequate ventilation such that they don't work. We really should not have to point this out. No more designing trailers with suicide doors, or doors that impinge on open windows or awning arms. Let's make sure when we introduce new products like (nest) that they are not an embarrassment to the brand. Test products to failure, then fix the problems discovered. Design-build-test. Let's design intelligently, not lazily, or not doing it at all. Think.
3) how about putting in a sub-floor that will not rot? Other trailers have aluminum flooring. There is also a remarkable composite material called coosa board that is just as strong and easy to work with as plywood, but is water proof, critter proof, mold resistant, and 30% lighter than plywood! Wow! The added cost of the material is a fraction of the total cost of the trailer but would last for decades, if not longer.
4) change the mindset of thor from milking the airstream brand for as much profit as possible, and focus instead on making the best tt on the market (while still making a handsome profit) and reap the rewards. In other words, be more like apple in this regard.
If airstream does this, it would set the standard in the domestic rv industry, become the quality leader in the market, burnish it's brand reputation, be more responsive to customer needs, innovate next generation technologies that are both useful and effective and set the company on the path to even greater success.
ditto 👆
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 08-16-2019, 11:57 AM   #11
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Skyguyscott covers the bases. I experienced the rotted floor in our old Bambi from a long term undetected leak.
I wonder, does Airstream have a Consumer Panel? With a new factory, production to ramp up, more models and employees, face-to-face feedback or input from a panel of users should be put in place. Hello? Airstream? Be a sector leader and put this in place. We have some REALLY smart owners out here!
banderabob is offline   Reply With Quote
Old 08-16-2019, 02:30 PM   #12
Bluffton , South Carolina
My Dream AS
Classic 28 Twin RB
Rap around rear windows
Recliners (Full)
And everything Skyguyscott said!!!
69SoulShine is offline   Reply With Quote
Old 08-16-2019, 03:20 PM   #13
Darby Mc's Avatar
2017 20' Flying Cloud
Appleton , Wisconsin
With front placed beds, please put the wall mounted reading lights on the other side. This would put the head of the bed on the curb side, and facing the outside door. Viewing the television from bed would now be possible. Plus it creeps me out not to be able to see the outside door from the current reading light placement, behind the wardrobe closet. Convenience and safety factors are my concern.
Darby Mc is offline   Reply With Quote
Old 08-16-2019, 03:20 PM   #14
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I would love a 23FB twin with a rear hatch to carry my 2@75 lb E-Bikes, the same layout as the 25FB twin only 2 ft shorter lounge.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
2021 Wish List for Airstream Foiled Again Airstream Lifestyle 2 05-07-2019 04:21 AM
XMAS Airstream Wish List eagletoo Our Community 14 12-14-2018 06:07 AM
West State of Jefferson, NorCal Free/Cheap CaddyGrn Boondocking 10 07-11-2015 10:21 PM
Wish List for Airstream 'Carport' Frank&Mike Winterizing, Storage, Carports & Covers 28 05-01-2013 06:47 PM
Jefferson Texas RV Parks kds On The Road... 0 11-06-2009 11:30 AM
