Old 03-31-2004, 07:48 PM   #15
Katt's Avatar
Thanks for the info.
KattnBri
Katt is offline   Reply With Quote
Old 03-31-2004, 08:05 PM   #16
North Central , USA
Originally Posted by argosy20
...the axle should be a torsion type, that is the springs consist of hardened rubber inside a steel tube. ...
Your unit looks great, have fun! I'm not sure if the hardened rubber 'torsion' axles were used 'back then'. You most likely have some kind of leaf-spring (possibly w/shock absorbers) suspension. On those type, the wheel spindles were welded to a 'dead'/solid axle-externally sprung. There is a wealth of info here, tap it! If replacement is in order, I'd look into a Dexter. I had a complete 'fatigue' failure on an older (circa '69) leaf-spring trailer while on the road, not fun!
RivetED is offline   Reply With Quote
Old 03-31-2004, 08:54 PM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Yes, they were...Maxwell has them and he's a '64. I believe '61 was the first year the Dura-Torque Axles were used instead of leaf springs.
Shari
Old 03-31-2004, 10:25 PM   #18
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
The axle is a torsion type as described above by argosy20...just like like my 65 Globetrotter.
You don't want to try to seal all the seams at this time. Only after ruling out the following:
  • Start looking first at the plumbing roof vents. The seals might have just dried up and need replacing.
  • Next look at the roof fresh air vents.
  • Then check around the windows or the window seals themselves.
  • Check around the fresh water tank filler in the front. Mine had no sealing left
  • Check around the water heater. A very common source for leaks.
  • The TV antennae mount in the front.
Look at the hitch yoke were the trailer wiring feeds into the steel. It was very common for water to travel along the cable inside and rust out the bottom.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 03-31-2004, 10:38 PM   #19
Katt's Avatar
Thanks Bobby, great info. So the torsion axle is better than the leaf spring, if I'm understanding correctly. Don't replace the axle unless necessary?
I will go over all the various places you suggested. But as a rule you don't seal the seams unless you're having leak problems? I don't think I have any leaks I was thinking of it as a sort of preventitive maintanence.
Did I mention that I love this site????
KattnBri
Old 03-31-2004, 11:04 PM   #20
BobbyW's Avatar
Houston , Texas
A torsion axle may or not be better than a leaf-spring. Torsions are lighter and they do last a long time.
Spring leafs can be "resprung" $.
Torsion axles have to be replaced. $$$$
www.Inlandrv.com has a good document about determining whether yours has failed.
BobbyW
AIR# 123
Old 04-05-2004, 09:23 PM   #21
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Hi Kat - and welcome to the neat world of Streaming. Peter and I just got our 69 Globetrotter this February. Yours looks great - not much to do nice and clean.
Where abouts in Ontario did you find her? (you mean we may not have had to travel all the way to Louisiana to get ours...)
Have fun with all the refit - and don't worry you are not the only one who has become obsessed with your A/S - I spend more time thinking and working on ours over anything else!!! ....and a lot of time is spent here - it is a wealth of knowledge and great ideas.
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 04-05-2004, 10:29 PM   #22
Katt's Avatar
We got it near Niagra on the Lake. I found a listing online and called and it was available. I so excited we towed it home Saturday. Read Take the good with the bad thread. You'll read all about the door incident.
Glad I'm not the only one who is constantly thinking about my AS.
Katt
KattnBri
Old 04-06-2004, 10:32 AM   #23
imeynstein's Avatar
Texarkana , Arkansas
Airstreams are addictive! You can't get enough--or at least I can't. Every time I turn around I am on this site---pretty bad huh!!
imeynstein
imeynstein is offline   Reply With Quote
The Official Airstream Web Site (Airstream.com) EJWeb Link Archive 3 06-11-2002 10:50 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
