Old 07-03-2002, 12:59 PM   #1
OPD controversy
Thought you all might not know that the new National Fire Protection Association guideline (code?) is creating some controversy out here in the Seattle area. It seems some 24 states have not adopted these guidelines that went into effect April 1st. Many people are trying to refill their tanks for summer barbecues and are told they can't because of the new national fire code. They later learn that this guideline is not being inforced by our state's Fire Marshal (my co-worker filled old his tank yesterday at U-Haul). I'm personally going to purchase new tanks as mine are in rough shape and their inspection date has expired. Anyway, I thought you would like to know that "what we hear is not always entirely true". I have included the link to our Seattle Times newspaper so you can read for yourself about whats going on. After bringing up the site, type "Propane Tanks" in the Search Archive box in the upper right corner of the front page. You will find a couple articles from the past two days. Enjoy!
http://seattletimes.nwsource.com/html/home/
Larry
Stougard is offline   Reply With Quote
Old 07-03-2002, 04:30 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Larry,
I've also found this to be true in TN. I spoke with our fire inspector and found that until the guidelines are written into Tennessee's version of OSHA (TOSHA), it will not be enforced.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-03-2002, 09:03 PM   #3
66TradeWind's Avatar
Images: 22
In Canada there is no OPD requirement yet, of course if travelling in the U.S. you may not be able to refill but at this point no problem in Canada
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 07-04-2002, 01:03 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Personally, I think the benefits of the new valves far outweigh the cost of conversion. The ease of removing the fittings without a wrench is just great, and the shutoff on refill has twice caught refueling people who were not paying attention to proper fill levels. I think the other feature that most may not be aware of is the shutoff that occurs if the valve senses a high flow rate, which could occur in the case of a broken hose.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-10-2002, 01:42 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Wink Propane cost in your area?
Just had my 'new' tanks filled today.
No problems. Just had to purge(at no charge) them first then, filled with propane. Simple operation.
cost in this area(NH):13$ per 30 lb tank
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-10-2002, 05:55 AM   #6
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
Vern,
Where did you get it for $13? I paid $16 at UHaul?
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 07-10-2002, 06:46 AM   #7
1984 29' Sovereign
Savannah , Missouri
propane
Morning Mark,
I went to Campers Inn on 101A..
Not bad,uh??
Vern
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 07-14-2002, 12:30 PM   #8
canny_banjo_man's Avatar
Yorkshire , England
Smile Different GAS.
Hi All....
When we visit FLA:, I fill up the rental at the local gas stations...whilst I have noticed a LOT of tourists used the B P station, and paying more 4 the pleasure in doin so...
.......When in Orlando....
...Chris.....
It's NICE 2B Important...but it's more Important 2B NICE...Chris.....
canny_banjo_man is offline   Reply With Quote
OPD valves for 40 pound aluminum bottle phred LP Gas, Piping, Tanks & Regulators 7 05-30-2009 11:56 AM
OPD valves... FAILURE!! Silver Bullet LP Gas, Piping, Tanks & Regulators 10 11-28-2003 08:07 AM
OPD valves, Sight Gauges & Remote Senders femuse LP Gas, Piping, Tanks & Regulators 1 04-29-2003 07:41 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
