Old 10-02-2014, 01:34 PM   #1
gomotomoto's Avatar
Longport , New Jersey
On-the-road tool kit. What's in yours?
I think I'd be a good idea to get a conversation going about essential tools to bring on the road. Here's my thinking, let me know if I'm missing anything.
socket set
vice grips
adjustable wrench
sears handy cut
screwdrivers
compact drill
wire strippers
pry bar
hammer
MIG welder (kidding)
What's in your basic kit?
gomotomoto is offline   Reply With Quote
Old 10-02-2014, 02:58 PM   #2
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Duct tape (of course)
Pop rivet puller
misc pop rivets
Electrical wire terminal crimper
misc wire terminals
Old 10-02-2014, 03:05 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Everything I did not have in the kit for the last repair I did on the side of the road. Nothing like experience to show you what you forgot. Mine is a basic tool kit - some would call it overkill, and a parts box from the fishing section at Walmart I use to hold all the small parts you need: bulbs, hose fittings, clips, screws, switches, fuses, and all the small parts I took off to remind me of what I fixed in the past - always useful when you pull into Camping World and want to restock.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-02-2014, 03:11 PM   #4
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
1/2 inch drive breaker bar and torque wrench with 3/4 in socket for wheel removal
Assortment of screws for interior repairs
First aid kit for injuries incurred during repairs
Shot glass for after the repair is done
Nomad518 is offline   Reply With Quote
Old 10-02-2014, 03:16 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Reflective vest. One for every person who is going to get out of the car by the side of the road, kept tucked under a seat so it can be put on before getting out. A former coworker of mine (now deceased) was crippled for life when he was run over by a hit-and-run driver while changing a tire by the side of the road. Staying safe while you work is just as important as doing the work.
That's also why I swapped out my set of three reflective triangles for three lighted collapsible traffic cones. Cones work better in daylight when they're easier to see than the triangles, and even at night since they have their own light they are easier to see than reflectors. Plus, many— but sadly not all— drivers have a natural aversion to running over cones because they're more recognizable as warnings.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-02-2014, 03:43 PM   #6
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
Zip ties. They held our awning together when it was needed.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 10-02-2014, 03:48 PM   #7
Goal15's Avatar
Dallas , Texas
Can of silicone spray.... good for loosening stuck awning arms, and a dash in the 7-pin connector before connecting can make quick work of any residual moisture or dirt that has settled on the pins in storage.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 10-02-2014, 03:59 PM   #8
terryV's Avatar
2002 31' Classic
Monroe , Iowa
all of the above PLUS a Boy Scout knife and a good multi tool, Sure Fire flashlight with extra batteries, .45 auto with 2 mags, and a PS90 with four 50 rd mags.
terryV is offline   Reply With Quote
Old 10-02-2014, 04:04 PM   #9
'06 75th Winick Prototype
Lockport , Louisiana
Oh God...
Growing up camping with my parents years ago, we ALWAYS broke down no matter what rig we had. So, I'm accustomed to having damn near everything you could ever possibly need on the road.
Extra Mobil-1 oil
Spare Mobil-1 75/90 gear oil for rear end and filling funnel
Extra funnel
Extra Distilled Water
Extra Coolant (old fashioned Prestone)
Extra brake fluid/clutch fluid (Motul RBF600)
Turkey baster (for flushing hydraulic clutch if needed)
Hitch grease/axle grease
Extra air bags for truck (even though I don't use them)
Original Bilstein rear shocks for SSR (I have Monroe Airshocks but you never know!)
Extra coolant overflow tank (GM quality known to split at the seams)
Jumper Cables 2 gauge
Hammer
Mallet
Two socket sets
Full tool box
Spare tire for truck (didn't come originally with a spare)
Tie-wraps/zip ties
Acryl-R
Stainless screws, nuts, bolts, washers, finishing washers
91% alcohol
Full assortment of polishing and cleaning and washing supplies and towels
Volt meter
Soldering iron/solder/electrical tape/various connectors
Spare roll of 10g wire
Spare string
Hat lights
Flashlights
Bicycle locks
Wheel chocks
Leveling blocks, plastic and wood
Aluminum hydraulic jack
Extra tranny fluid
K&N cleaning kit
120v tester/amp reader
Stainless cleaner
Foaming window cleaner
Scott Towels
Latex gloves
Extra hubcaps (they tend to come off even when RTV'd)
MAF cleaner
WD-40
Toilet chemical
Extra hitch parts/pins/ball socket
Trailer wiring converters (just in case I have to tow something else)
Aluminum Stepladder
Extra throw rug/mat
Extra tire pressure gauges
Air compressor
Extra fuses
Bug spray
Bubble levels
Bungee Cords (mostly to keep the drawers and fridge closed)
Rubber tie-down straps
Broom/dustpan
Minidisc player/minidiscs
Bottle of Seafoam
Full assortment of rags and towels
Jewelers screwdriver set
Wood glue
RTV/3M clear marine silicone adhesive
Extra belts
Dielectric grease
Lugwrench/socket set
Electric impact wrench
Extra hoses
Bottle of Redline Water Wetter for radiator (just in case)
Extra hoseclamps
...and on this last trip I forgot the damn 30 to 20 amp adapter. Gak.
75TH BAMBI is offline   Reply With Quote
Old 10-02-2014, 05:04 PM   #10
richinny's Avatar
2011 34' Classic
http://www.airforums.com/forums/f312...it-116169.html
http://www.airforums.com/forums/f295...it-102727.html
and if not listed in those threads... a credit card and phone. :-)
Ricky
Old 10-02-2014, 06:50 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
  • Duct Tape
  • WD-40
  • Pump Pliers
  • Vise Grips (large pair so they can double as a hammer
In reality my tool kit is a bit more involved. We used to refer to the above tool list as the Dash 8 overhaul kit as in DeHavilland Dash 8
Probably the one thing that has saved me a lot of grief has been an roll of aluminum foil tape, the kind with the release paper that has to be removed. It makes a super temporary patch over a leaking rivet until I can get to where I can deal with it properly.
Aaron
WBCCI #XXXX AIR #2495
Old 10-02-2014, 07:31 PM   #12
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
socket set
vice grips
adjustable wrench
sears handy cut
screwdrivers
compact drill
wire strippers
pry bar
hammer
Actually I carry a cheap flux core MIG!! Unfortunately we have had to use it on the Alaska highway at least once and wish I had it another time.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 10-02-2014, 08:22 PM   #13
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I agree with your basic hand tools with the following niceties:
Waterless hand cleaner
Tire Plug kit for a temporary fix
12 Volt air compressor
A gardening foam knee pad to save your knees
Mechanix gloves
an LED light
I always buy the best tools that I can afford. If the repair causes misery, at least you have a nice tool to appreciate.
NavyCorpsman is offline   Reply With Quote
Old 10-03-2014, 01:07 PM   #14
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
I also carry a roadside assist card. (Good Sam's, etc.) and charge cell phone.
Sent from my iPhone using Airstream Forum
Twinke58 is offline   Reply With Quote
I'll Show You My Dent If You Show Me Yours! Rubyslipper Ribs, Skins & Rivets 42 12-22-2016 07:10 AM
Airstream Interstate Tool Kit Ron_CA Sprinter and B-van Forum 6 06-07-2014 08:31 PM
What do you carry in your LY road tool kit? RhinoWW Land Yacht/Legacy Motorhomes 10 02-15-2014 10:50 PM
Road Tool Kit Reay 2005 and newer - Bambi all models 15 03-25-2013 02:17 PM
I'll Show you Mine If you'll show Me yours... joossens Link Archive 0 05-12-2004 12:51 AM
