Originally Posted by Jimandrod
I just got off the phone with my AS dealer....
good job!
carpeting is a personal preference issue, warm feet are nice.
but imo carpet is a LOT of trouble in a travel/camping trailer.
it absorbs odors, and dirt like it's magnetic.
the the carpet a/s uses is, well UGLY and cheap.
IF you have carpet using a vacuum becomes mandatory, while solid surface flooring can be mopped, swept or 'swiffered'...
IF you have carpet, putting the plastic liners INSIDE all carpeted outdoor storage areas is a great idea,
BUT be careful, because moisture can STILL collect under the water proof layer and cause issues.
all rvs eventually have WATER inside, from rain or plumbing leaks or sink/toilet overflows or water pump failures, tank/vent tube leaks...
i've had ALL of these and so will almost every other camper eventually.
with carpet, drying out after these issues is a MUCH bigger problem as is dealing with the remaining ODORS...
it is DUMB that sheet vinyl costs EXTRA, carpet should be the OPTIONAL flooring choice 4 those that really want it in a 'stream.
i think they STILL USE CARPET because it goes in QUICKLY and HIDES SLOPPY fit/finish issues.
area rugs can be rolled up, removed, cleaned better, taken out for storage and colors/textures easily changed on a whim.
i was using latex/rubber backed area rugs, the 'non slip' versions, and still use a couple...
but have returned to using WOOL area rugs and jute/sissal? they don't hold odors, are more durable and generally better overall.
cheers
2air'
