Old 07-03-2010, 10:30 AM   #15
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
If your investigation involves taking the electric motor head off your jack, be sure it's timed correctly when you put it back on. One of the first jobs we had to do on our Safari was replace a gear stripped by a badly timed jack.
Basically, the jack should stop electrically in both directions before it stops mechanically. Fortunately, the PO had kept the instructions for ours.
Old 07-03-2010, 11:02 AM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by Journalist View Post
You would think that more people would recognize a blinker fluid drain plug tool when they see one...
Many people have mistaken the tool for a Blinker Fluid Drain Plug Remover, much to their distress. The Blinker Remover does not have the hexagonal hole; it has a Grundig Doubletwist hole for the plug. Using this tool to remove the drain plug may result in refrundification and render the tool inoperable when you most need it for tricentrification and to operate the twin turbine plasma drive oscillators. At that point you will have to use the stick with rope attached for further vacuum clarifying.
This tool should not be used without proper safety gear because of reported instances of anticrundosis.
Gene
Old 07-03-2010, 11:35 AM   #17
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
My mistake, Gene. I completely forgot about the plasma drive oscillators. Having those out of whack could certainly cause a misalignment within the waste particle acceleration unit's guidance system, that, as we all know, can cause premature axle failure.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-03-2010, 11:46 AM   #18
Ambie '64's Avatar
1964 28' Ambassador
Oklahoma City , Oklahoma
Geez! And I thought it was just a window crank with the hole all hogged out! You just learn so much on these threads.
Ambie '64 is offline   Reply With Quote
Old 07-03-2010, 11:49 AM   #19
Master of Universe
Gene's Avatar
We're here to help.
Gene
Old 07-03-2010, 12:26 PM   #20
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
It's a very specialized tool for when you need to tighten both a 1/4" and 3/4" nut that are right next to each other. Slip the tool over both nuts, and turn the crank handle - voila! Both nuts will tighten at the same time. Of course, one of the nuts needs to be in a different space-time continuum, but I did say it was a very specialized tool.
Hopefully you figured out what it's really for by now.
Chris
Old 07-03-2010, 01:18 PM   #21
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The piece looks rather small..maybe couple inches long. I wonder if it could be for cranking open the roof vent in your kitchen. On my trailer, the plastic cover for the lights has a plastic crank with a hex fitting. Maybe for your model year, they did not make the crank and all that is there is a hex bolt? This particular vent on my trailer is hard as heck to open and is rectangular in shape.
4RXLA is offline   Reply With Quote
Old 07-03-2010, 02:12 PM   #22
Splitrock's Avatar
Sioux Falls , South Dakota
Jack cover off
I see a big nut under the motor.
The big nut looks like it'd fit the big hole in the wrench. Using the wrench would involve removing the motor from below . . .
There's only two bolts where there's space for 4. I think the PO carried a hydraulic jack for raising the tongue without the electric power.
I can't believe how much I'm learning on this project.
Old 07-03-2010, 05:20 PM   #23
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
it looks like the smaller hex hole might fit the nuts under the motor. Maybe you use it to remove the motor to make accessing the larger nut easier. Be careful not to start any disconbobulation when trying this.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-03-2010, 06:01 PM   #24
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
well, that AND improperly balanced wheels.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 07:15 PM
The unbelieveable Ride of the Wrench Mainstream On The Road... 18 06-05-2010 10:59 AM
Lug wrench - sizes? Jammer Wheels, Hubs & Bearings 16 01-27-2010 10:56 AM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 07:27 PM
Wrench Sizes rmmm68 General Repair Forum 1 01-14-2003 02:05 PM
