Old 07-28-2003, 06:46 PM   #1
noobie question, A/S wieght
I am a jeep( read noobie) when It come to the airstream. I am wondering what the wieght of the airstream is? I am wondering what size I should look for to pull?
It more than likely be a rebuilder/resto/ mod type as it would be in my price range and accually seen a couple that I may check on?
Tim
Airstreamlover is offline   Reply With Quote
Old 07-28-2003, 06:50 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
There are many different models and weights. If I read you right, you have a Jeep? Checked your profile and no help there either.
Can you post specifically what your car/truck is and I am sure a bunch of folks can jump in on info and suggestions.
Eric
Old 07-28-2003, 07:30 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Tim!
Welcome to the Forums!
Depending upon year, model, and equipment; you may have a very modest or a relatively wide array of potential Airstreams to choose from. Probably the most capable Jeep tow vehicle was the pre-1991 Jeep Grand Wagoneer with the 360, 390, or 401 cubic inch V8. I towed my '64 Overlander for about two years with a 1984 Jeep Grand Wagoneer with the 360 V8 and heavy duty trailer tow package - - the only down-side was its maximum cruising range while towing of 180 miles. The later model Jeep Wagoneer/Cherokee vehicles with the V8 and heavy duty trailer towing package are generally considered to be best for the 24' and under trailers weighing less than 6,000 pounds.
You will need to check your Jeep to determine its trailer tow limit. The trailer tow limit can be determined by a Jeep dealer if it isn't readily apparent by reading the owner's manual. Another less precise method is to determine the GVWR (Gross Vehicle Weight Rating) of your Jeep then find the GCVWR (Gross Combined Vehicle Weight Rating) - - trailer towing capacity is then the GCVWR less the GVWR - - this forumula, however, does not take into account frontal area restrictions that are used by some of the manufacturers.
When you know the towing limitations of your Jeep, you can check the weights and measures pdf at the Airstream web site to determine whether a particular trailer is within the capabilities of your tow vehicle.
Airstream Weights and Measures
The thing to remember when looking at these weights is that for the older models the only weight given is the Dry Weight - - the dry weight is the weight of the coach without options, empty tanks (water, LP, black water tank, and gray water tank if so equipped), and no personal possessions on board. For the later trailers, GVWR is the gross vehicle weight rating or the maximum that the loaded trailer can weigh without violating its engineering specifications. The ideal, and with Airstreams it is relatively easy to achieve, is to have between 12% and 15% of the total trailer weight on the hitch - - another possible consideration as some vehcile manufacturers will also limit maximum tongue weight as well as maximum trailer weight and frontal area in their trailer towing specifications.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-28-2003, 07:56 PM   #4
I think the Jeep was a little missleading . I guess being in the milatary for 9 years had an effect on me. in the USAF geep means inexperianced,green, new, fresh.
For a tow vehicle right now I have a 95 Explorer XLT, 4.0 v6 4x4. but by the time I get an Airstream I may have upgraded to something bigger. Time will tell.
Tim
Old 07-28-2003, 08:32 PM   #5
Aluminut
2004 25' Safari
. , Illinois
I would say International 16' CCD or 19' Bambi max given the vehicle.
Eric
Old 07-28-2003, 09:25 PM   #6
Here is a link to all the Airstream weights going back to 1954:
http://www.airstream.com/airstream/p.../weights-1.pdf
Note that these are empty weights without any options.
Mark
Which A/S can we tow safely with our Toyota? silvernewbie Tow Vehicles 15 03-01-2004 08:53 PM
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 01:50 PM
1st Timer A/S: Tow-Hitch Question RivetED Hitches, Couplers & Balls 5 01-27-2004 09:10 PM
New a/s owner question on furnace/toilets baddog Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-23-2003 12:24 PM
