So far since using our '71 with out a grey tank last year and this year we have only stayed at full hookup resorts.
Which are nice but sometimes you are too close to your neigboors and the sites are not very remote.
I was thinking of getting one of those blue tank toters, like the 22 gallon one. But with 4 of us showering and washing dishes I just don't know how pratical it really is.
I assume I would be dumping it daily.
I am not talking about boondocking here, just state campgrounds which don't typically offer sewer connections.
I would like to try camping closer to a river or on a beach.
How do others w/o a grey tank handle this?
Also our black tank is only like 12 gallons and the four of us fill that up real quick. At least every two days. Do you use the tote tanks for black water as well?
Tim, my 31 does not have a grey tank and the black tank is around 17 gallons. I use my 22 gallon blue tank for grey water and to dump the black tank without moving the coach. Depending on how you shower, you may get one or two showers in the grey tank.
This past weekend we had minimal grey water, as we used the CG's showers, which were excellent. I used the blue tank to dump the black tank once. I have the hitch for the 22 gallon unit that slips over the ball of the trailer hitch. Makes it a lot easier.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
We too love the state park campgrounds so I have already thought about this situation.
Although we haven't been on our maiden voyage yet (next weekend...yippee!!) we are planning on using the bath house toilets as much as possible and using the AS toilet only for those middle of the night circumstances.
We will likely use the bath house for showers as well (provided they are clean...so far haven't had any problems).
We have no gray tank.
We have the 22 gal blue tank also riged to tow to the dump station. I have been thinking of changing out the wheels for the inflatable rubber tires you have to go very slow when pulling the blue tank and the wheels are starting to look rough.
With just the two of us it is not bad. I use the CG facilities most of the time and my wife uses the AS. I dump once a day or sometimes every other day. Black every two three days.
A full 22 gal tank will weigh something like 180 lbs. - about all any of us would want to push and pull around, even if you tow it for the most part.
The mess should be minimal, but sanitation is a bit harder. Harbor Freight puts disposible latex gloves on sale every now and again for less than $4.00 per 100, which solves the issues very cheaply.
Seems like most like the 22 gal. So I guess that would be the way to go not too small and not too big....
Just remember that the tank when full will weigh close to 200 pounds. Make sure that you orient it so that you can make use of leverage to get it to the hitch.
I find my 10 gal tank is a hassle when full. It has wheels, but not the means to hitch it up. I used to make use of it to dump the recirculating toilet in my SOB TrailManor.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Originally posted by j54mark The mess should be minimal, but sanitation is a bit harder. Harbor Freight puts disposible latex gloves on sale every now and again for less than $4.00 per 100, which solves the issues very cheaply.
Mark
A very good point. A box of disposable gloves rides under my back seat and they go on as soon as I pull up to the dump station. or when I get ready to dump at a full hookup.
Take care also in removing the gloves. Turn them inside out, being very careful not to touch the outside.
John W. Irwin
