To the engineer - run do not walk to the nearest exit - you won't like it.
To the romantic - write a check now, the smiles will out pace the miles.
To the financial analyst - the payback in $s is a future value sum.
To the mechanic - you can work on it forever and make it better and better.
To the realist - no slides to leak, rivets and seams will, tows well, looks nice.
To the buyer - you are never unhappy with your final decision.
First - we bought one.
Second - we looked at others and we liked it better.
Third - there is a lot of info on AS, that helps you make fewer mistakes.
Fourth - they use the same appliances other RVs use, no better, no worse.
Fifth - AS is a two season coach, the ribs that support the skin transfer heat.
Sixth - the Airstream company has evolved over time. So quality, innovation, and reliability have changed over time. When RVs did not sell, cost got cut; when doing well, the safety and quality research got done and better coaches were built. There are a few big mistakes - older 22 frames were a problem. When you fix something, lots of interior comes out. Not all the components are as high end as the purchase price. The recent expansion of the AS factory has had growing pains. It is perceived quality on some coaches suffered. Fit and finish suffers on some and is perfect on others. Your dealer makes a huge difference as they catch or miss big issues. Find a good one, visit the factory, decide for yourself.
Seventh - there are other options, look at the plastic ones. However, AS owners do like their coach. WBCCI is cool. The vintage folks are fantastic and often just plain artists. Aluminum is shined by returning the oxidation to it's pure elemental condition, not by sanding the oxidation off.
Eighth - The RV world needs DIY folks. Do not believe someone else will do it all, unless you have tons of time and money and patience.
Ninth - ASs are a fundamental part of the RV world. You may be a Winnebago fan, but everyone is an AS fan ..... except the Silver Streak and Avon folks who know there can be a better mouse trap.
Tenth - We bought one and will never buy another. This one is a keeper.
Hope to see you down the road. Pat
